You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Anybody know a place that sells the plastic collar for a tilt steering column. Ford P/N D5AZ-3511-B.
It's described as the upper Flange in the Ford repair manual page 13-06-10. It's the part that surronds the column where the tilt lever goes in to the column.
New or Used is O.K.
Dennis Carpenter, LMC, Mac's doesn't have it
__________________ 1979 Ford F-100 Custom
300 six with P/B P/S A/C Cruise A/T. Power Locks and Windows. (with a new rust hole in the floor board)
(My daily driver) in the summer time http://www.ford-trucks.com/user_gall...oid=20955&.jpg
I don't have a catalog handy, but check NPD (National parts depot) or LMC they should have the parts for you. They do have websites also.
Toyman
Already did that, they don't have one. Thanks anyway
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1. You can get more with a kind word and a 2x4 than you can with just a kind word.
Dennis, says he may have one. I also need the lower bearing and housing assembly. Fits into the end of the column. Bronco Graveyard shows one in there cataloge, but in reality that have a fabercated one I've seen on eBay. I want the original. What I want to do is replace both bearings before I put the column in my truck.
John
John
I'll take a look-see...then look at the usual suspects...er obsolete parts sellers, give me 20 minutes or so.
Watch this post...more info being added...
Round COVER = D8TZ-3D505-A upper bearing goes here / This comes next = round FLANGE D5AZ-3511-B
Lower bearing goes to D4AZ-3D651-A = tilt wheel LOWER flange. Is this what U mean by the lower housing??
EDIT:BOTH BEARINGS ARE STILL AVAILABLE....sorry for shouting, this new system sucks, cuz you can't add color or bold type when editing, and with me, editing is a way of life!
I'll see what's available = these numbers are typed from a 20 yr old parts catalog, so now I have to verify whether these numbers are still viable, or have been replaced.
Will type what I find in another post.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
Lower bearing assembly P/N D8TZ-30681-A < < No it's not, there's no such part number as D8TZ-3D651-A. There's no complete assy, the flange & the bearing come separate.
The following is the correct part number for the lower flange: D4AZ-3D651-A.
flange P/N D8TZ-3D505-A This is the upper steering cover, fits above the 3511, the upper bearing goes here.
Ask Dennis to post this illustration: Section 35 / Page 31
It'll make life one heck of a lot easier when you can see the setup. 1978/79 tilt column illustration. / Dennis has the catalog on a CD, I'm using microfiche, I can't scan that! :-(
D4AZ3D651A .. Lower Flange, Use with Tilt Wheel -Obsolete- I haven't looked around for this yet...
(when typing part numbers into websites, the hyphens/spaces have to be removed, otherwise you'll get: No parts found.
Are you looking for 3D505, also??
Upper bearing & lower bearing are the same part, correct #3517. Why the difference in price?
Thanks for jumpin in here bill. I tottaly forgot about you!
__________________
