Michigan Chapter Join Chapter, Leader: Toyman
Need Plastic Parts for a tilt steering column
Old 04-20-2008, 01:46 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Sgt Wonderful is offline
Anybody know a place that sells the plastic collar for a tilt steering column. Ford P/N D5AZ-3511-B.
It's described as the upper Flange in the Ford repair manual page 13-06-10. It's the part that surronds the column where the tilt lever goes in to the column.
New or Used is O.K.
Dennis Carpenter, LMC, Mac's doesn't have it
Old 04-20-2008, 08:12 PM
Toyman's Avatar
Toyman
Toyman is offline
I don't have a catalog handy, but check NPD (National parts depot) or LMC they should have the parts for you. They do have websites also.
Toyman
Old 04-20-2008, 08:51 PM
Sgt Wonderful
Toyman
Already did that, they don't have one. Thanks anyway
Old 04-21-2008, 08:45 AM
Talyn's Avatar
Talyn
Talyn is offline
For your old truck, john? Or for a newer one?
Old 04-21-2008, 09:13 AM
Sgt Wonderful
For my 79 Ford
Old 04-24-2008, 03:30 PM
Toyman's Avatar
Toyman
Toyman is offline
did you find the parts you need yet? somebody should be repopping those by now.
Toyman
Old 04-24-2008, 03:59 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
D5AZ-3511-B .. Flange-Use w/Tilt Wheel / OBSOLETE
But it does fit other models...
Fits:
1975/79 Econoline / 1978/79 F100/350 / 1978/79 Bronco / 1975/78 LTD & Mercury Marquis / 1975/79 Lincoln Town Car
1975/79 Thunderbird / 1975/79 Mark IV & V / 1975/76 Torino/Mercury Montego / 1975/79 Cougar
1977/79 LTD II (1979: NOT an LTD - LTD II's have stacked dual quad headlights).
1975/76 Mustang II / 1976/80 Granada/Monarch / 1977/80 Lincoln Versailles
No Ford obsolete parts seller I searched has one (including Green Sales), no Ford dealer has one either.
EDIT: Try FTE sponsor BRONCO GRAVEYARD.
Bronco's, F100/350's: 1978/79 only = 1980 and later is different.
Econoline: 1975/79 only, 1980 and later is different.
Old 04-24-2008, 04:01 PM
Sgt Wonderful
Plastic Part
Dennis, says he may have one. I also need the lower bearing and housing assembly. Fits into the end of the column. Bronco Graveyard shows one in there cataloge, but in reality that have a fabercated one I've seen on eBay. I want the original. What I want to do is replace both bearings before I put the column in my truck.
John
Old 04-24-2008, 04:23 PM
NumberDummy
John
I'll take a look-see...then look at the usual suspects...er obsolete parts sellers, give me 20 minutes or so.
Watch this post...more info being added...
Round COVER = D8TZ-3D505-A upper bearing goes here / This comes next = round FLANGE D5AZ-3511-B
Lower bearing goes to D4AZ-3D651-A = tilt wheel LOWER flange. Is this what U mean by the lower housing??
Bearings: C7SZ-3517-C .. Upper / E1FZ-3517-B .. Lower = replaces C7SZ-3517-D.
EDIT:BOTH BEARINGS ARE STILL AVAILABLE....sorry for shouting, this new system sucks, cuz you can't add color or bold type when editing, and with me, editing is a way of life!
I'll see what's available = these numbers are typed from a 20 yr old parts catalog, so now I have to verify whether these numbers are still viable, or have been replaced.
Will type what I find in another post.
Old 04-24-2008, 04:38 PM
Sgt Wonderful
EDIT > LOWER HOUSING = WHAT DOES THAT MEAN? WHERE IS IT?
UPPER FLANGE = D8TZ-3D505-A / LOWER FLANGE D5AZ-3511-B
Lower bearing assembly P/N D8TZ-30681-A
flange P/N D8TZ-3D505-A
Old 04-24-2008, 05:20 PM
NumberDummy
Lower bearing assembly P/N D8TZ-30681-A < < No it's not, there's no such part number as D8TZ-3D651-A. There's no complete assy, the flange & the bearing come separate.
The following is the correct part number for the lower flange: D4AZ-3D651-A.
flange P/N D8TZ-3D505-A This is the upper steering cover, fits above the 3511, the upper bearing goes here.
Ask Dennis to post this illustration: Section 35 / Page 31
It'll make life one heck of a lot easier when you can see the setup. 1978/79 tilt column illustration. / Dennis has the catalog on a CD, I'm using microfiche, I can't scan that! :-(
D4AZ3D651A .. Lower Flange, Use with Tilt Wheel -Obsolete- I haven't looked around for this yet...
C7SZ3517C .. Upper Bearing / MSRP: $39.98 / ftepartsguy.com: $28.79
E1FZ3517B .. Lower Bearing / MSRP: $10.37 / ftepartguy.com price: $7.78
(when typing part numbers into websites, the hyphens/spaces have to be removed, otherwise you'll get: No parts found.
Are you looking for 3D505, also??
Old 04-24-2008, 05:57 PM
Sgt Wonderful
Upper bearing & lower bearing are the same part, correct #3517. Why the difference in price?
Old 04-24-2008, 06:57 PM
NumberDummy
I cannot say, that's Ford's doing.
3517 is just the basic number, when the prefix and suffix are added, that makes a complete part number.
The lower bearing: C3DZ3517A & retainer: B1AZ3518A
Those 2 bearings I typed earlier (C7SZ3517C & E1FZ3517B) are both considered upper bearings.
Old 04-27-2008, 05:02 PM
Talyn's Avatar
Talyn
Talyn is offline
Thanks for jumpin in here bill. I tottaly forgot about you!
Old 04-27-2008, 06:00 PM
Sgt Wonderful
William, how could you?
Quick Reply: Need Plastic Parts for a tilt steering column
