Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-20-2008, 01:44 PM
PITMASTER is starting off with a positive reputation.
Upsizing my tires on my 2006 E-150 - NEED HELP!!!
I need new tires for my 06 E-150 passenger van. Stock size is a P235/70/16 Mich. LTX (29 in tall). I think the tires look a little small for the van and was thinking of going to a 245/75/16 (30.5 in) or even a 255/75/16 (31.1 in). I'm wondering about clearance inside the wheel wells while turning and I already know about the speedo issue. I hope you guys can help me out as I will have to order the tires by Monday. Thanks.
  #2 (permalink)
Old 04-21-2008, 04:55 PM
V10E350's Avatar
V10E350 is starting off with a positive reputation.
I had 265s on my E350 and they rubbed a little in hard turning. I went back to the stock size of 245s and there is plenty of clearance. All vans share the geometry and essentially have the same clearance, just softer or less capable suspension.
__________________
2007 Ford E350 4x4 (Quigley)
V10, 5R110, 4.10
  #3 (permalink)
Old 04-21-2008, 09:54 PM
YoGeorge is gaining momentum as a positive member of FTE. YoGeorge is gaining momentum as a positive member of FTE.
Quote:
I tried 30x9.50x15's on my '02 in lieu of the 235/75x15's. They fit just fine (29.5 inch diameter) but between the larger size and the gnarlier tread (Firestone Destination AT's) I lost a full 2 mpg--after adjusting for size difference. Fortunately, Firestone had a 30-day money back deal, and I got some 235 Michelin LTX M/S's on it, returned the Firestones, and lost a net of $40 or so for mount/balance fees, which I recouped in gas savings in not a long time.
Especially if you have a 4.6, the engine will have a harder time pulling the van around with larger tires and you may lose some mileage.
I'd go with a slight upsize to 245/70x16's and call it a day....
  #4 (permalink)
Old 04-22-2008, 09:52 PM
clev is starting off with a positive reputation.
My 1985 E-150 w/351w 4bbl came with 235/75R/15's. I opted to change them to 30/9.50/15's many years ago and have not looked back. The fuel economy sucked from the beginning, 11 ~ 13, and it's still the same with the 9.50's. The 9.50's look and ride better, plus they have a higher load rating. I've been using them since about 1993, will NEVER get rid of Ol' Brownie, and will continue using them.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
