Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 08:15 PM
SHERIFFWoody's Avatar
SHERIFFWoody is starting off with a positive reputation.
vin# and plante help ples.
ok. I have looked all over can not find any thing to help on the vin# and plate on my truck. Can someone tell me if thay can what my truck is ples ? Most of the paint on the plate is gone so all I have is numbers I will try my best -top then left to right and down left to right -F10JK423294 114 T f100 81A A 12 5000 114 3600 63 -thk you
  #2 (permalink)
Old 04-19-2008, 08:31 PM
camperspecial65 is gaining momentum as a positive member of FTE.
Heres the skinny...
F= conventioal cab truck
10= F100 series...1/2 ton truck
J = 223 1bbl 6 cylinder engine
K= Kansas City assy.
423,294= 1963 model assembled in June
114= wheelbase in inches
T= sandshell beige
F100= model of truck...see above
81A = conventional cab truck with a beige interior.
A= 3 speed manual trans. L/D
63= DSO= Memphis...where truck was ordered from originally
the numbers prior to the DSO are the engines net H.P. at the shown RPM's, followed by the trucks load rating(GVWR) in pounds.
- cs65
  #3 (permalink)
Old 04-19-2008, 09:05 PM
Thank u so very much. now I can get to work on restoreing my Food truck .
  #4 (permalink)
Old 04-20-2008, 12:24 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
AXLE CODE: 12 = Ford 9" / 3.89-1 / non Limited Slip / 3300 lbs. Rear Axle Capacity
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #5 (permalink)
Old 04-20-2008, 05:53 PM
oops...I missed a rear axle code...thanks for catching it Bill
- cs65
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
