Ok, I loaded my new tweecer with the stock flash, and what I mean by that, I simply read the ford eec and wrote the file to the tweecer position 1. When I have the tweecer in position 1 the fuel pump runs constantly when I have the key in the on position, and while it does start, it runs horribly. I mean it is on the verge of stalling.
Shouldn't it work just like the it would without it if there are no changes made? BTW it is a Non RT Tweecer, and a MUG2 ecm, and I did use the AGANN Definition file.
Please help!!!!!
__________________
95 F-150 5.8 4x4 E4OD, Now with OBDII & MAF!!!
When you read the eec did the data look OK or was it scrambled? What I mean is are the scalars the right value when you compare them to other bin files from the web?
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
I got another tweecer and it works fine, I think....
no constant fuel pump anyway. Can't figure out how to disable the crankshaft position sensor and the rear o2 sensor. Yeah I posed, and no responces yet.
__________________
I finally found a harmonic balancer with a tone ring and I installed the sensor for it.
I am getting o2 sensor errors though. sensors 11,12, and 21 all reporing heator error. Randomly reports failure. I have been trying to disable the rear sensor, which is 12 I think. there are soo many switches. Bank 1 and 2 downstream, rear o2 sensor switch, and sensor switch 2 and 3.
Any ideas conanski?
Chris
__________________
