Look for the big yellow wire right at the bottom of the picture.
Right below the yellow wire you can also see the side of a grey connector that still has a green wire with a red stripe on it.
Mine did about the same thing, when I started looking the grey connector was melted on the side the yellow wire was in.
I cut the wire as close to the connector as I could, the used a copper split bolt to reconnect the wire, and taped it all up good so it could not short out.
The yellow wire is the main power into the cab from the battery.
