Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 04:15 PM
mike31 is starting off with a positive reputation.
E-250 engine noise
Ford Motor Company’s Technical Article: Ethanol/Methanol Fuel Blends:
Ford Motor Company vehicles should operate normally if the customer uses blends that contain no more than 10% ethanol or a blend that contains no more than 5% methanol with its necessary co-solvents and additives. If the methanol does not contain the necessary co-solvents & additives, it will damage the vehicle.
Gentlemen I would like as many opinions as possible on this subject.
I bought new a 99' E-250, From day one it had an engine noise that sounded like rods rattling or a chain rattling from the engine. It became louder as the engine became older it currently has 80,000 miles.
To date I have spent a small fortune trying to find the cause.
New Mass air flow,cleaned injectors,New intake manifold gasket,plugs,egr parts ,new computer,upgrade software,all new 02 sensors, coils,
Experts have said, standard engine noise,to piston slap.
I just started using 89 octane with 10% Ethanol and the noise completely went away. I am on my 3rd tank with no noise at all. before this I was afraid the engine was going to blow, the noise was getting really bad.
A mechanic said for $1000 He would replace my brake booster which has a vacuum leak per code this would also rid the engine of it,s noise.
Could it be the vacuum leak had the computer adjusted to max and I was getting a poor burn, which the higher octane now has a hotter burn bringing it back closer to normal? just a theory?
any thoughts please.
  #2 (permalink)
Old 04-19-2008, 08:14 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
if this is the case then you woill be able to tell by
sealing off the vacuum line to the brake booster
will make it hard to stop but only done as a
temp. measure to test for the leak
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #3 (permalink)
Old 04-19-2008, 09:36 PM
I will do this, and thank you for the reply, do you think a booster vacuum leak would put the computer past it's fuel trim adjustments and caused a poor burn and the higher octane brought it back?
It would be really funny if I had a bad booster from day one and the computer and knock sensor just keep trying to adjust the fuel trim.
I seem to be getting close to an answer just would like to know for my own head. Thanks
  #4 (permalink)
Old 04-20-2008, 08:42 PM
mhg mhg is offline
with the computer controlled sys. any leak throws it off
any unmetered air is not allowed by the computer
__________________
1996 E-350 351
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
