Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 02:37 PM
RDC F250 7.3 is starting off with a positive reputation.
Engine Swap!!!! Cab Off or Not????
F-450
Just asking whats easier, Or maybe some tips on what to do.
Bought an 2003, 17K miles, complete for 2700.00 with freight.
Start the removal today, any help on this would be great.
Thanks
__________________
1985 Ford L8000, Cat 3208 250K+ Miles
1989 Ford L9000, Cummins L10 500K+ Miles
1998 Ford Expo, 5.4L -235K+ Miles
1999 Ford F250, 7.3L -264K+ Miles
2003 Ford F450, 6.0L -134K+ Miles
  #2 (permalink)
Old 04-22-2008, 09:57 PM
Lil Help needed still!!
__________________
  #3 (permalink)
Old 04-22-2008, 10:44 PM
a-rod's Avatar
a-rod is gaining momentum as a positive member of FTE.
If it was me I would pull all the coolers and upper radiator support and pull the motor out the front. I think thats the easier way, but some like pulling cabs.
__________________
Adam - - Collision/Refinishing Tech
2002 7.3 POWERSTROKE
100,000 miles
Straight Pipe, 6637, HPX line, pryo gauge, Foil Delete, WW, 6.0 IC + TC. Superchips Tuner.
F-350 Rear Blocks, Leveling kit
  #4 (permalink)
Old 04-23-2008, 01:31 AM
rollerstud98 is starting off with a positive reputation.
If you know how to pull the cab I've heard its quicker that way then taking it out the front. But if you have no experience with that method I'd recommend doing in the old fashioned way of out the front. Remove all that crap thats sittin out front and you'll have yourself a big gaping hole to work with.
  #5 (permalink)
Old 04-23-2008, 07:26 AM
brickie's Avatar
brickie is gaining momentum as a positive member of FTE.
If the truck is a standard the clutch has to come off to get the motor out the front.To get the clutch off the transfer case and of course the tranny has to be let go first.PITA
__________________
03/04 350 Crew DRW 6 speed XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. AFE filter, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM
03 Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
  #6 (permalink)
Old 04-23-2008, 09:14 PM
hayfrmr318 is starting off with a positive reputation.
I had to replace a frame on a 2003 4-door long bed, and pulling the cab wasn't as hard as I thought it would be. I would suggest doing that, cause once the cab is off you have TONS of room.
Just my thoughts.
__________________
2004 F-350 6.0L.
Superchips Tuner.
4" MBRP Cat-back exhaust.
Auto meter Pyro.
2" Leveling kit.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
