Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil & Lubrication
Sign in using an external account
Register Forgot Password?
Oil & Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
  #1 (permalink)
Old 04-19-2008, 12:48 PM
tuckerjw tuckerjw is offline
Garage is empty, add now
tuckerjw is starting off with a positive reputation.
Explained: Oil for flat tappet engines
Found a great article on selecting the right oil for older flat tappet engines. This guy seems to know his stuff. The article is a bit long (29 pdf pages) and can be a bit academic but I found it very informative. The author is rebuilding an old corvair but all of the info is germane to our old Fords. He does a good job dispelling many of the myths I've seen on this site. Enjoy!
I recommend going to the web site HERE and downloading the pdf.
  #2 (permalink)
Old 04-27-2008, 06:16 AM
89Flivver 89Flivver is offline
89Flivver is starting off with a positive reputation.
Some review of the SAE peer reviewed papers going back to 1976 to 2006 are here for your obsession:
Specializing in Real Time Systems Engineering Solutions
  #3 (permalink)
Old 04-27-2008, 01:54 PM
Shamus's Avatar
Shamus Shamus is offline
Shamus is starting off with a positive reputation.
Nice find. Thanks.
__________________
1978 F150 Explorer 75th Anniversary Edition
  #4 (permalink)
Old 04-27-2008, 09:50 PM
Stumpalump's Avatar
Stumpalump Stumpalump is offline
Stumpalump is starting off with a positive reputation.
Last month I called Shells lubrication lab enginers and Mobil lubrication enginers lab. This is what they told me that was important enough to remember and share: The best oil for flat tappet engines is 15w 50 unless you live in Alaska or Canada. ZDDP levels are highest in these weights and Shell recomended their Rotella 15w40 and Mobile only recomended Moble One extended performance only in 15w 50. The turbo oil is ok to mix in if you live in Alaska and want to thin it. These oils have basically the same amount of ZDDP as oil made back in the day when your Jeep was built. Is this enough ZDDP to break in a new cam. No! Thats why the factory added ZDDP to break in oil. Once it's broken in then the oils listed above will protect a flat tappet engine. Note the weights of the oil listed again.
This is how ZDDP works: It only works on hot spots in your engine above 500 degrees F. At this temp it bonds with the hot metal hot spots and forms a hardened alloy. ZDDP gets used up very fast and is why engine builders change it a few times while it's still being broken in on a dyno. I'd change your oil at least 3 times durring the first 1000 miles when using a flat tappet cam and also add GM or Ford beak in or assemble lube added as an addative.
The sigle best oil you can buy to run with a flat tappet cam is Moble 1 Extended performance but only in the 15W50 weight. Rotella is good stuff also and even the brand new stuff comming out has been improved way beyond what you would expect. You can't run the thin weight synthetic. You still need the 15w 40. Buy the Mobil 1 and pick up 4 or 6 bottles of GM assembly lube to add 1 to each oil change. If it were me I'd change every 300 miles till 900 then every 1000 miles till you hit 5000. Remember they told me ZDDP gets used up real fast in a moter being broken in. The old cam in my old engine will last only because it spent the first couple of years of it's life running with the same levels of ZDDP of the two oils I told you about and the steel has been turned to a hardened alloy by it. It has nothing to do with the way the cams are made today. It has to do with how they were or were not bathed in the hadening propertys of ZDDP.
  #5 (permalink)
Old 04-28-2008, 11:25 AM
R-WEST R-WEST is offline
R-WEST is starting off with a positive reputation.
Here's http://www.turbodieselregister.com/TDR57_Oil.pdf some good reading for those looking for high ZDDP numbers.
  #6 (permalink)
Old 04-28-2008, 03:06 PM
some oils have lowered/increased additives. to keep up the article at Specializing in Real Time Systems Engineering Solutions has been updated 3 times in 6 months in an attempt to keep up.
Tags
best, corvair, engines, explained, flat, ford, oil, tappet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
