Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered Bonus Built, Classic and Box Style Ford Trucks
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 01:39 PM
potemkin's Avatar
potemkin is starting off with a positive reputation.
1950 F-1 Starter is Just Spinning!
Just tried to get it ready for spring and the starter all of a sudden isn't catching. It is the original starter on the original 239in flathead. Any quick fixes out there? Why would this just suddenly happen?
  #2 (permalink)
Old 04-19-2008, 02:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1 is gaining momentum as a positive member of FTE.
I'd pull it out and check the starter drive. It may have gotten rusty, but I kind of suspect it's loose on the shaft. May indicate a broken spring.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree
MSD dizzy, 2110 Holley, Red's Headers
  #3 (permalink)
Old 04-19-2008, 03:35 PM
ssj7kids's Avatar
ssj7kids is starting off with a positive reputation.
WOW, is that your truck.... WOW
I want to paint mine Meadow Green (original) as well.
GREAT TRUCK
__________________
Steve
53 F100 Flathead 8
Listen to advice and accept instruction, that you may gain wisdom for the future.
Proverbs 19:20
  #4 (permalink)
Old 04-19-2008, 03:48 PM
bobj49f2's Avatar
bobj49f2 is gaining momentum as a positive member of FTE. bobj49f2 is gaining momentum as a positive member of FTE.
What Ross said. I had the spring snap, it's not very hard. If you've never taken your starter out be careful. First remove the battery cable (of course) Then remove the small bracket that bolted from the top bolt of the starter and the oil pan but don't pull the starter bolt completely out. loosen the bottom bolt and try to remove the starter as one piece. There is nothing holding the starter together and it will fall apart in a few pieces, pulling the amature out of the brushes which can be a pain to get back in.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 8N tractor
48/51 F-4 flatbed (2 in 1)
  #5 (permalink)
Old 04-19-2008, 06:49 PM
ALBUQ F-1's Avatar
That is a gorgeous truck -- nice to see a stocker!
__________________
Ross
  #6 (permalink)
Old 04-19-2008, 09:39 PM
4tl8ford's Avatar
4tl8ford is gaining momentum as a positive member of FTE.
You may have sheared the bendix bolt.
Pull the starter as bob described.
__________________
Dick C
Erie, PA
1948 Ford F1 Panel
1997 Ford Explorer
http://www.4TL8Ford.com
1/20/2009
End of an Error
  #7 (permalink)
Old 05-24-2008, 01:57 PM
potemkin's Avatar
After some minor health issues I'm back at it again! Took out the starter (thanks for the heads up bobj49f2, I'd forgotten that trick). Found the problem, now I just need a solution.
On the shaft and pinion assembly the bolt ("SCREW-11382" on page 269 for those of you out there with a 49-51 shop manual) sheared. I need a new bolt and one of those lock washers with 2 tangs on it that get bent, one down and one up once the bolt is tightened to keep things cozy. The front bolt on the starter driver head ("SCREW-11377) appears to be identical.
Anybody know where I can get one of these bolts and washers? Anybody have an old original 6 volt starter laying around that they would be willing to send the bolts off of?
Again, thanks guys.
Best,
Potemkin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
