Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 11:03 AM
sons73 is starting off with a positive reputation.
Help on cooling decision
Hello. I need help deciding on how to cool my sons truck we are finishing.
1973 F250 4x4, 390 rebuilt about 300 miles ago.
We put in a summit aluminum radiator with a pair of electric fans that come installed in a shroud.
Radiator: Summit SUM-380428 - Summit Aluminum Racing Radiators - summitracing.com
Fans:
Derale 16927 - Derale High Output Rad Electric Fans - summitracing.com
The temperature is fine while driving (about 180-185), but starts to heat up in traffic, it got to 230 last night. I thought this set up would be more than enough, but it has not even started to get hot here! I am leaning towards trying to put in a taller , 24 high instead of 19, one since I will need to do some modifications due to a 2” body lift.
I do not have any parts, so I would need a new radiator, shroud, and fan assembly if I go that route.
So, I would like words of wisdom. What would you all recommend? I would like to keep it as cost effective as possible, but it MUST work. Thanks in advance!
  #2 (permalink)
Old 04-19-2008, 04:20 PM
gbadgley is starting off with a positive reputation.
If the fans are set up on a thermostat, I would play with the off/on setting or try a toggle switch to kick them on. If they are already on with the key, either more fan or more radiator. Greg
__________________
If I can't fix it, I can screw it up so bad no one else can either!
  #3 (permalink)
Old 04-19-2008, 05:06 PM
Grumpy Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
If you go back to the original setup.
D3TZ8146C .. Fan Shroud ~ Fits: 1968/76 360/390 ~ Used with standard, Xtra cooling and A/C radiators, not used with Super Cooling radiator.
Still available from Ford.
MSRP: $93.30 / ftepartsguy.com: $67.18
The largest radiator Ford supplied for this shroud was used with A/C.
Specs: Heighth: 19 3/4" / Width: 26 1/4" / 2" core thickness / 3 row.
The Super Cooling radiator is the way to go, but both it and its fan shroud are very hard to find.
Super Cooling radiators used a different core support, so to install a S/C radiator in a truck that didn't come with one, you have to trim away some metal in your present core support for the radiator to get enough airflow.
S/C radiator specs: Heighth: 24 11/16" / Width: 26 1/4" / 2 5/8" core thickness / 4 row.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #4 (permalink)
Old 04-19-2008, 05:32 PM
I am going by the local Pick and Pull to see what they have. The truck has been a two-year project with my son, frame up, and I would like to stick with new/reman parts as much as possible.
The fans are set to go on at 180, and they turn on between 180-185 by the guage.
I was looking at these:
Radiator, Super Cooling
Fan Shroud, Super Cooling
I know it is a 3 row, and not as thick, but???
Find a fan at the local Pick and Pull and use a clutch?
I am pissed I wasted the $ on the aluminum and fans, we learn by doing.
Trimming, better described as hacking for me, I can do.
ND, I see you are from LA, you must know about sitting in traffic
  #5 (permalink)
Old 04-19-2008, 05:36 PM
It's EZ to tell a S/C radiator from the others when it's still in a truck, or not.
The top tank on the S/C radiator is almost 6" wide, about 2" wider than the A/C radiator.
S/C radiators were used from 1968 thru 1979. Besides the 360/390's, the 460's used the same one: D3TZ-8005-G.
All Ford fan shrouds are marked on the upper drivers side corner. The mark is molded into the shroud.
S/C radiator shroud: MARKED: D4TA-EB / A/C radiator shroud: MARKED: D3TA-CA (this is the shroud that's still available from Ford).
Sitting in traffic: Not anymore, I'm retired.
I don't venture from the house till 10AM. and am back by 2PM, times which usually avoid the horrid traffic conditions.
btw: I'm in LA County, not the city. It doesn't matter where you live, the traffic is awful no matter where you go.
LA County: 8 million ppl have taken up residence here, and that not counting the estimated 2 MILLION illegals!
LA traffic = IMO, it's not as bad as San Francisco, and compared to Toronto, it's a piece of cake.
__________________
  #6 (permalink)
Old 05-04-2008, 12:55 AM
hotrod351 is starting off with a positive reputation.
best setup i found for cooling is go with a fan clutch and 8 bladed fan, find the fan in a wrecking yard, and use the electric fans as pushers, that works on my jeep and can feel the difference when i switch them on.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
