1961 - 1966 F-100 And Larger F-Series Trucks
Discuss the Slick Sixties Ford Truck
04-19-2008, 10:08 AM
Who needs an instrument panel?
04-19-2008, 04:43 PM
Ford Parts Guru
Quote:
Originally Posted by
Gillseeker
LOL
You do
not want it = it's for an F500 or larger truck!
The tach is from a
BIG Ford truck. It wasn't used in light trucks.
These tachs are driven by a
cable off the
distributor.
Good luck finding a tach drive dizzy for a FE engine.
There are two tachs like this.
One is for a gasser and has a
GREEN band between 25 and 40 (C3TZ-17260-F).
The other has a white band between 25 and 40 and it's for a
DIESEL (C3TZ-17260-E).
C3TZ = 1963 part number, what the seller sez is marked on it.
I can't make out a
GREEN band in the picture, so guess what?
Now you know the reasons why the seller never installed the cluster in HIS truck.
The clusters were painted white from the factory, not black.
The Stewart Warner gauge wasn't factory installed.
The original oil pressure gauge failed and was replaced by the SW gauge.
It's not so awesome anymore, is it.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
04-19-2008, 05:11 PM
THAT'S why we like having you around!
You saved me 30 bucks!
Dan
04-19-2008, 05:16 PM
Ford Parts Guru
Gillseeker
You saved me 30 bucks! Dan
I"m round all right, that's part of the problem.
Another part of the problem is, I'm an opinionated crabby old grouch.
I could diet away a few pounds, but once a grouch, always a grouch.
__________________
04-19-2008, 09:55 PM
Now for the dumb question of the day! That tach was for a diesel right? How do you run a cable off the distributor for the tach if it's a diesel?
Just out of curiousity- what diesel would have been in a 63 heavy duty truck?
__________________
Charles F. Rives III
65 F-100 2wd-352 4v various mods, pretty quick
83 F-250-Obnoxious 6.9 Diesel on 36's
85 Bronco-still sittin stock, 300 I-6
86 Bronco-Eddie Bauer 408w stroker
04-19-2008, 09:59 PM
Upon closer inspection of the ebay pic, it almost looks like there IS a green band, but I'm not 100% sure.
__________________
04-20-2008, 07:28 AM
Ford Parts Guru
cfrives3
Now for the dumb question of the day! That tach was for a diesel right? How do you run a cable off the distributor for the tach if it's a diesel? Just out of curiousity- what diesel would have been in a 63 heavy duty truck?
I have no idea how the tach drive cable works on a diesel, and I ain't gonna look, but the fact of the matter is, here's two examples...and there are more.
C4TZ-17365-D .. Tachometer Drive Cable-Fits: 1964/69 F600/800 330/361/391 FT Engines.
C3TZ-17365-M .. Tach Drive Cable-Fits 1961/69 F950/1000
CUMMINS V6
Diesel 588 cid.
C3TZ-17365-AJ .. Tach Drive Cable-Fits 1961/66 C600/700
DAGENHAM & DORSET 6 Cyl 330
Diesel .
There's about 50 more of these cables for other models.
Diesels in 1960's Ford trucks: CUMMINS / DAGENHAM & DORSET (English) / DETROIT / CATERPILLAR
__________________
04-20-2008, 10:15 AM
I wasn't saying you were wrong. Not at all. I've just never seen a diesel with a dist. before.
__________________
04-20-2008, 10:56 AM
Redneck Has Been
if I had to guess I would say it came from a 700 series with a Dagenham,Dorset or Detroit
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
04-20-2008, 12:01 PM
Tach drives for diesels run off a boss on the fuel injection pump......
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive DOHC, EOD.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
04-20-2008, 12:26 PM
Redneck Has Been
garbz2
Garbz
some but not all
__________________
Ray
PAA #35
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
