Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-19-2008, 07:30 AM
russ2387's Avatar
russ2387 is starting off with a positive reputation.
37" spare tire? what do u use?
what do you all with large tires use for a spare tire? with a tire/wheel combo at $800 a piece its hard to justify getting a 5th wheel as a spare.{at least it is until your stuck in the middle of nowhere, and who stocks 37's?}. is there a cheap alternative? was wondering if i put the original spare {32"} in the front and kept in 2 wheel drive it would be ok? at least till i get home? getting a beach sticker soon and one thing they check is a spare tire...
  #2 (permalink)
Old 04-19-2008, 07:45 AM
350z is starting off with a positive reputation.
I was planning on doing the same thing. As long as you have two of the same diameter on the back your limited slip will be ok . And your hubs unlocked .
Whats the biggest size tire that will fit under the truck?
__________________
04 F350 5.4l auto 4x4 sc sb lariat,buckets,4.10LS, plow,camper/overload springs/rear sway bar,FX4,pwr pedals&slider,backup sensors,heated/lighted mirrors,cab lights,Gibson stainless exhaust,FTVB,6"superlift w/diesel springs,35's,bilstein5100's,alarm/remote/pager,undercover
  #3 (permalink)
Old 04-19-2008, 07:58 AM
russ2387's Avatar
Quote:
well its an 08 with 6'' lift but will sit 7'' over stock so at least 38's i think. why?
  #4 (permalink)
Old 04-19-2008, 09:32 AM
Green Ford's Avatar
Rats...mmmmm
Green Ford is starting off with a positive reputation.
I have 38.5's and a 38" spare. The guys at 4wheel parts gave me one used tire for a spare.
__________________
'03 F-250 4X4 CC 5.4L SB Lariat FX4 a few mods...
  #5 (permalink)
Old 04-19-2008, 10:02 AM
bigskymt's Avatar
bigskymt is starting off with a positive reputation.
I don't run 38's.. but when I ordered my wheels I ordered 5. Replaced 2 of my older BFG's and kept 1 for a spare.
I got a Fabtech spare tire mount and had a welder fab this up for me, it uses the 2 bolts that the tie down bracket uses so I didn't have to drill:
Minor adjustments are still needed, the blue Fabtech cap needs to be centered on the wheel and the mounting bolt needs to be flipped so the good side of the wheel will face outward.
It does create a blind spot, I would have put it on the other side but I have my hi-lift jack mounted there.
__________________
1999 V10 F-250 Supercab, Centerline Hellcats/BFG AT's, Rancho 9000XLShocks, Warn Trans4mer, Leer Topper, Kenwood/Infinity Stereo
  #6 (permalink)
Old 04-19-2008, 11:42 AM
DCSpecial's Avatar
FTE Sponsor
DCSpecial has a very good reputation on FTE. DCSpecial has a very good reputation on FTE. DCSpecial has a very good reputation on FTE. DCSpecial has a very good reputation on FTE.
I have a cheap 38" spare with a Fabtech mount holding/locking it in the bed.
__________________
  #7 (permalink)
Old 04-19-2008, 11:48 AM
gross30's Avatar
WORK IN PROGRESS
gross30 is starting off with a positive reputation.
I found this to work well for me, and can haul my quad at the same time. Holds up to a 40" tire.
  #8 (permalink)
Old 04-19-2008, 12:06 PM
brmpipes is starting off with a positive reputation.
Quote:
nice look.I have the tiregate also swong in though,and it holds my 37in tire nicely
  #9 (permalink)
Old 04-19-2008, 12:14 PM
gross30's Avatar
WORK IN PROGRESS
I swing it inward when not hauling the quad around, works great and easy to work with.
  #10 (permalink)
Old 04-19-2008, 02:00 PM
russ2387's Avatar
any ideas on where to get a cheap spare tire and rim?
  #11 (permalink)
Old 04-19-2008, 04:14 PM
thedaddycat is gaining momentum as a positive member of FTE.
One thing to take into consideration is that if you get a matching spare tire/wheel you can then do a 5-tire rotation. This should extend tread life by 20% and you will not have to worry about changing two tires(due to mismatched size) if you get a flat on the rear. Is it worth the extra money? That's entirely your call....
__________________
'03 F-350 XLT 6.0 PSD SRW SC SB FX4
Dieselsite coolant & tranny filters, Bright Box,
22" wipers, M-H FD RD Tranny covers, Fluidamper, leveling kit
TAG, Power Elbow, Blisteins, gages, MBRP 4" Cat-back
XCal2 by SDT, HFCM drain, Centrimatic balancers
ESP luber, Oilguard bypass filter
  #12 (permalink)
Old 04-19-2008, 04:20 PM
DCSpecial's Avatar
FTE Sponsor
For a cheap 37" spare, get one and put it on one of your stock wheels.
__________________
  #13 (permalink)
Old 04-19-2008, 04:54 PM
Arrow
Sorry Russ, I was talking about the factory spare location under the bed , on that hoist.
__________________
  #14 (permalink)
Old 04-19-2008, 06:43 PM
russ2387's Avatar
ahhh. makes sense now lol
  #15 (permalink)
Old 04-19-2008, 06:47 PM
FordSDF250 is starting off with a positive reputation.
yea how big can fit under the truck I have 35's and I have a stock spare. also i have a 2001 f250 if that helps determine the size max
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
