Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-18-2008, 09:38 PM
ericfgs is starting off with a positive reputation.
02, e250, 5.4L cat (right)
ok, I have come to the conclusion I need a right side cat. I have eliminated the reasons why it failed. A single cat isn't available form normal auto part stores. $1200 list from the dealer and that is the entire y pipe. I did find a place in CA that can send me the y pipe for 1/2 that. Do I just go ahead and stick a high flow cat on it? Any suggestions??? Thanks
  #2 (permalink)
Old 04-19-2008, 08:05 AM
Clubwagon is starting off with a positive reputation.
I would find a good local muffler shop and price a cat from them. If you have a cat/y-pipe single assembly then it will be expensive.
Mine had an integrated y-pipe/cat assembly and it was somewhat expensive. I had a good local muffler shop cut the cat off and install a separate y-pipe and high flow cat. It worked great. I am very happy with it.
__________________
Steve
'95 Clubwagon XLT
  #3 (permalink)
Old 04-19-2008, 04:38 PM
Thanks for the reply. My problem is the van is barley moving. There is no way I'd be able to get it somewhere without towing it. Just so I understand, did you have to replace the entire Y assembly or did they remove it and replace the cat and reinstall it?
  #4 (permalink)
Old 04-23-2008, 12:17 PM
redford's Avatar
redford has a very good reputation on FTE. redford has a very good reputation on FTE. redford has a very good reputation on FTE.
What I did was go to a muffler shop and just ask them to "fix it" as cheaply as possible. They did a little custom work at the Y-pipe and added a universal catalytic converter for a little under $200.
To get the van to the shop, disconnect the exhaust at the manifold.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73 LS Tow Command
Presently working as a military contractor in Afghanistan.
  #5 (permalink)
Old 04-23-2008, 12:37 PM
The shop that did the work cut the pipes ahead of the Y and the cat. They then fabbed a simple Y pipe and installed the cat.
I should note that the '95 has two inlets into the front cat, one from each side. So there is no separate Y. Then there are actually two cats. The front cat has the two inlets, one outlet into the primary cat. The shop replaced both the front and rear cats with a single, high flow cat.
__________________
Steve
'95 Clubwagon XLT
  #6 (permalink)
Old 04-24-2008, 06:33 AM
Thanks for the info, I'm going to make some calls today. This van has 3 cats.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
