Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Shock Absorber Reviews
Reviews and comparisons of top products
Bilstein Shocks Installation on my F-250
on
Hey John... after seeing your photos I think maybe I installed my rear Bilsteins shocks up-side down.. However, mine are a bit different than yours. Mine have a smooth blue plastic cover verses flex rubber.. I called Bilstein prior to installing and they said to install them so the "lettering" on the shock is normal to read.. which mine are. Is your lettering normal on the rear shocks.?
Yes, the printing is right-side-up on my shocks.
I mentioned this. It was screwing with my mind and at first I tried to install them blue-side-up with the writing up-side-down since I thought that is the way I always saw them especially with the pics on the net of the Hijacker shocks. But the Bilstein shocks basically will tell you what side to install where if you listen to the shocks instead of doing what I did and cussing at them to get them on.
I thought both ends had the same size holes. Instead, one side had a steel bezel or spacer in the rubber grommet. The other end has a larger hole that is all rubber without a steel spacer.
The rubber side side goes on the fixed stud and the steel spacer fits the bolt-n-nut side on bottom.
Your set is different. Your smooth plastic sleeve needs to be up top so that water does not collect like a cup.
On my shocks they seal off the flexible boot and have weep holes on the bottom to drain any moisture.
Yours look more the the stock shocks with the sleeve up top. I almost bought the same set as you but others advised me to get the model numbers I spec'd since it was Super Duty.
I hope I explained this okay. If not maybe someone else can chime in and explain this better.
If ya look at the shock ends..... you can only install them the correct way... Like John said before.. The one hole is bigger with all rubber... that end goes to the top where the big stud is.. The other end with the metal collar in it goes to the bottom... doesn't matter what shock you get.... They all will only go on the one way !!!!
on
