Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Exhaust Systems
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-18-2008, 08:24 PM
redneckfarmers is starting off with a positive reputation.
Manual pipe bender
I have a manual pipe bender you know a hydrolic jack in a little frame with pipe dies bought for about $100 and i was wondering if anybody knows what one of these will do to exhaust pipe before i go buy pipe and try it myself Thanks
  #2 (permalink)
Old 04-18-2008, 08:48 PM
dkf's Avatar
dkf dkf is offline
dkf is gaining momentum as a positive member of FTE.
It won't work good, I mean it will bend it but it will probably crip the pipe bad. Below is a pic of a 3" pipe I took off my truck that a local exhaust shop bent on a non mandrel bender. You can see how much the bender crimped the pipe. The ID of a 3" 16ga. exhaust pipe is a tad more than 2.875", at the bend the it measured that pipe measured 2.375" and that was only a 20-25 degree bend.
  #3 (permalink)
Old 04-18-2008, 09:47 PM
ghunt is starting off with a positive reputation.
Yep it'll crush the crap out of it...
__________________
1994 F250 XLT-4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust, custom intake, pyrometer & boost gauge
http://www.cardomain.com/ride/3055099
1987 Thunderbird Turbo Coupe-P&p head, FMS A237, Esslinger Star, p&p intakes, bob's log, big FMIC, UPR shifter, subframes, MM STB & K-brace, etc.
http://www.cardomain.com/ride/306349
  #4 (permalink)
Old 04-19-2008, 01:09 AM
Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.Truckin4life has a good reputation on FTE.
quick question... what is the difference in a regular pipe or tubing bender and a mandrel bender? Just wondering... I know it will give you different bends... But how do they work?
__________________
Don
Stg's Minions: 12 volt specialist
1995 f-250 ext. cab, lb. 4x4, 5.8 5 speed. Performance mods, and a heavy foot.
Quote:
Originally Posted by STGFordCrazy04 View Post
X2 and hes not talking about truck nuts
Welcome to the Minions house.....Giving correct answers since 2007.
  #5 (permalink)
Old 04-19-2008, 01:23 AM
khadma's Avatar
<I really look like this
khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.khadma has a great reputation on FTE.
Mandrel benders have a follower inside the pipe.
The other type compresses the pipe.
Here is some information.
I have a Manual bender that uses a die and a follower on the outside of the pipe.
Tube Bending Techniques
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
1988 Mazda B2200
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #6 (permalink)
Old 04-19-2008, 07:07 AM
flowriteexhaust is starting off with a positive reputation.
The piece that rides inside the pipe is called the mandrel and slides inside the pipe to keep it uniform while bending. A chrome mandrel is used for aluminized pipe and a bronze one for stainless steel. They have very close tolerances to the thickness of the pipe, you can't use the same mandrel for 16 guage pipe and then 14 guage pipe. The dies and mandrels run between $3500 and $5000 dollars. So if your bending aluminzed and stainless, you need 2 sets of dies. Very expensive proposition, our mandrel bender cost $70,000 and we probably have $175,000 in dies and mandrels
  #7 (permalink)
Old 04-24-2008, 12:25 AM
Dave Severson is gaining momentum as a positive member of FTE.
I buy mandrel bent aluminized tubing and a couple of lengths of aluminized straight pipe and build my own exhaust systems. It's time consuming, but you get the system you want without all the gimpy looking bends that the regular exhaust tubing benders leave....
__________________
Anybody can restore a classic, takes a man to cut one up......
  #8 (permalink)
Old 04-24-2008, 05:33 PM
slinger34 is starting off with a positive reputation.
My buddy made a bumper out of exhaust tubing and if you fill the tube with sand it will not crip like that. It is worth a try see if it works for you.
  #9 (permalink)
Old 04-24-2008, 08:22 PM
where do you get your exhaust supplies dave i know i can get the straight pipe locally but where could i get the bends at? so you just fill the tube with sand weld caps on the end and bend it the cut the caps off right i might have to try that but im still interested in buying the bends and doing that way i think it would be a lot faster
  #10 (permalink)
Old 04-24-2008, 09:12 PM
kens64 is starting off with a positive reputation.
Thats an old skool method of bending pipes. The trick is to get it packed as tight as possible, so it doesnt let the pipe crush when you bend it. Works well. Takes forever.
You can get bends everywhere online. Try Summitracing.com or Jegs.com
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
  #11 (permalink)
Old 04-24-2008, 11:52 PM
He welded the ends after packing the sand in. Remember leave a little extra material for when you cut the ends off.
  #12 (permalink)
Old 04-26-2008, 01:34 AM
khadma's Avatar
Brass instrument builders (trumpets etc) freeze water in the tubes and then bend the tubes. I guess it might work large scale too.
Try to find a fab shop in your area, ask them for mistake bends from the scrap pile.
__________________
1995 Windstar
1988 Mazda B2200
Darren
  #13 (permalink)
Old 05-02-2008, 06:31 PM
V10man's Avatar
V10man is starting off with a positive reputation.
JCWhitney has the best prices on mandrel pieces.
__________________
2007 Dodge 3500, 6.7L Cummins, A/T, exhaust brake, 4x2, long bed, white.
1992 F150 4x4, 5.0, a/t, stepside, K&N, Flowmaster, 93,000 miles
  #14 (permalink)
Old 05-03-2008, 05:00 PM
Our prices are better than jc whitney and you can get 5 degree increments all the way up to 90 degrees ( 10, 15, 20, 25, 30, 35, 40........85, 90 degrees) and 10 degree increments over that (100, 110, 120, 130........180 degrees)
  #15 (permalink)
Old 05-03-2008, 06:27 PM
Stumpalump is starting off with a positive reputation.
I have heard of the sand trick and also ways to modify it to fit the tube you are bending. The one I saw had a slightly large tube welded into what they call a die to get the shape correct. I have also heard of grinding them out to fit the pipe or tube you want. You can search real tube benders but they will run you about 500 pluss for a real one and you have to buy all the dies seperate for about 200. Try these threads because the off road crowd is real familiar with them:Pirate4x4.Com Bulletin Board
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
