Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-18-2008, 07:20 AM
trucksforlife29 is starting off with a positive reputation.
Talking Engine Info
Hey everyone I need as much help on this as fast as possible if ya'll can. I putting my truck in a car/truck show Sat. What I need from anyone who can help me on this is all the numbers and specs on the 352 in my truck that can be given to me. I plan to put up a poster board beside my truck with all of this info on it to give people and judges an Idea of what exactly is under the hood and any other details that I can think of. I have seen other people that have done this and not only does it look good but it gives you a professional apperance as well. So any help with this between now and tonight would be greatly appreciated. Thanks
  #2 (permalink)
Old 04-18-2008, 10:46 AM
Mike G is starting off with a positive reputation.
What kind of info would you be after? The 352 FE was first put into trucks in 65 and lasted to 67, then they went to 360 and bigger. The motor had been in production since 1958. It is a member the FE family of engines. It has 208HP, but i can't recall the TQ numbers...
--Mike
__________________
Mike G
1965 F100 LWB .060 over 390/beefed C6
1968 Cougar XR7 (wife's toy)
2002 Chev Avalanche
1992 GMC K1500 4x4
2001 Infiniti I30
2004 Honda CRF250R
2003 XR50 w/big bore 80cc kit
1990 Chaparral 2000SL 20ft bow-rider 5.7L Merc
Yes...there are only three licensed drivers in the household
  #3 (permalink)
Old 04-18-2008, 11:56 PM
rusbukt's Avatar
rusbukt is starting off with a positive reputation.
352
352 FE V8 Introduced in 1958 as part of the Interceptor line of Ford V8 engines, the Ford 352 (of 351.9 in³ or 5.77 L displacement) was the replacement for the Lincoln Y-block. It was simply a 332 with 3.5 in (102 mm)stroke and a 4.0 in (88.9 mm) bore, and was rated from 208 hp (155 kW) with a 2-barrel carburetor to over 300 hp (224 kW) on the 4-barrel Police Interceptor models. This series of engines usually weighed over 650 lb (290 kg), and were all known for excellent torque and durability.
Applications:
2V
8.9:1 — 220 hp (164 kW) at 4400 rpm and 376 ft·lbf (510 N·m) at 2400 rpm
1961-1963 Ford
4V
10.2:1 — 300 hp (224 kW) at 4600 rpm and 395 ft·lbf (536 N·m) at 2800 rpm
1958 Ford Interceptor (civilian)
1958-1959 Ford
1958-1959 Ford Thunderbird
9.6:1 — 300 hp (224 kW) at 4600 rpm and 380 ft·lbf (515 N·m) at 2800 rpm
1960 Ford
1960 Edsel
1960 Ford Thunderbird
10.6:1 — 360 hp (269 kW) at 6000 rpm and 380 ft·lbf (515 N·m) at 3400 rpm
1960 Ford
8.9:1 — 235 hp (175 kW) at 4400 rpm and 350 ft·lbf (475 N·m) at 2400 rpm
1960 Ford
9.3:1 — 250 hp (187 kW) at 4400 rpm and 352 ft·lbf (477 N·m) at 2800 rpm
1964-1966 Ford
8.4:1 — 208 hp (155 kW) at 4000 rpm and 310 ft·lbf (420 N·m) at 2800 rpm
1965-1967 Ford F-Series
__________________
That stuff that comes out the back side of my Ford. Smells like Chevy.
  #4 (permalink)
Old 04-19-2008, 12:09 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
Who sez the FE engine was a replacement for the Lincoln Y Block?
That's BS!
The FT engine was the replacement for the Lincoln Y block (as used in large trucks only), not the FE engine.
The Lincoln Y blocks (279 & 317) were used in 1952/55 F600 and larger trucks.
The Lincoln Y Block derivitives (302/332) were used in 1956/63 F600 and larger trucks.
Replaced by the FT 330 M/D, 330 H/D, 361 & 391 in 1964.
No Ford car ever used a Lincoln Y block-ever.
No Lincoln ever used an FE engine-ever.
The only Ford passenger car to use a Lincoln engine was the 1959/60 T-Bird which offered the M-E-L 430 as an option.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #5 (permalink)
Old 04-19-2008, 12:28 AM
rusbukt's Avatar
Wasn't me !
Wikipedia said that. It is an online encyclopedia where you can search for history on just about anything.
__________________
  #6 (permalink)
Old 04-19-2008, 12:35 AM
Ford Parts Guru
Wasn't me !
Wikipedia? LOL...I should have guessed!!
Wikipedia is full of errors on most any subject.
Someone said it's better than nothing, but that's their opinion.
Wikipedia.. ..what a friggin joke!
__________________
  #7 (permalink)
Old 04-19-2008, 12:58 AM
rusbukt's Avatar
So how ya been grumpy ? I'm still waiting on that cowl molding for my 65 Custom Cab?
And while I got ya here. Where did the stock tailpipe exit under a 1960 short bed. Has a 292 in it. Out the back or in front of ride side tire? Or should I post it in other forum ?
Thanks for settin me straight on the FT FE. Have a good eve.
Frank
__________________
  #8 (permalink)
Old 04-19-2008, 01:37 AM
Ford Parts Guru
And while I got ya here. Where did the stock tailpipe exit under a 1960 short bed. Has a 292 in it. Out the back or in front of right side tire? Or should I post it in other forum ?
Frank
When I see Wiki Wiki being cited as a source for anything I'm interested in, grumpy ain't the word for what my feelings are.
The moulding is yours (I promised Don the other one) when I dig it out, and the tailpipe extended just past (or up to) the rear axle, right side on 1957/60 F100/350's, just like they did on most other Ford trucks thru the 1990's.
Even the 1952/64 OHV 6 bangers (215/223/262) tailpipes ended up on the right side.
1952/64 cars with the 215/223 engines = same-o same-o.
The exhaust (and intake) manifold on these puppies is on the drivers side.
__________________
  #9 (permalink)
Old 04-19-2008, 06:40 AM
jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE.
rusbukt, You are correct the FE was introduced in 58, but as the power plant for the new Edsel car. 1965 was the year the 208 HP FE was introduced to the pickup.
Grumpy, you call Bill grumpy???????
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
