GT40 head ID, how to ID non P gt40 heads? - Ford Truck Enthusiasts Forums
Old 04-18-2008, 06:12 AM
spidermonkey's Avatar
spidermonkey spidermonkey is offline
spidermonkey is starting off with a positive reputation.
all,
I have a chance to buy a set of GT40 heads...all the seller can tell me is he sees a code "GT" and "3D50". I've searched the archives and found that the GT40P have a "P". How can you confirm if the heads are regular GT40 and not GT40P? I have my 351 apart from my 94 F150 and and would pick up these heads if they are regular GT40's (don't want header surprises trying to match up the "P's" to my BBK headers.
Thanks in advance and apologies if I missed the answer in the archives.
Kind Regards,
Old 04-18-2008, 07:35 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The GT40 heads will have 3 vertical bars on the end, while the P version had 4 bars.
Old 04-18-2008, 09:40 AM
perfect. thanks!!
Old 04-19-2008, 02:04 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
Remember you will have to enlarge the head bolt holes to provide clearance for 1/2" bolts if the heads are from a 302, since that engine uses smaller 7/16" bolts.
Old 04-19-2008, 08:01 PM
klause85f150 klause85f150 is offline
klause85f150 is starting off with a positive reputation.
Is the difference between the p and non p heads intake volume or combustion chamber size/shape? I too have a 351 and am pondering the swap. Either way, how much would I be missing between the P and non P when taking into consideration that the heads currently resideing on it are the HO heads it came with?( I am assumming the only diff between the non-HO and HO is the carb and cam?)
Cheers!!
Old 04-19-2008, 10:21 PM
Conanski's Avatar
The P heads spark plugs stick almost straight out at a 90 degree angle and make putting headers on the motor almost impossible, they're generally not worth the trouble unless you can fab custom headers.
Both the GT40 and GT40P heads are upgrades from the regular heads.. which is all the 351HO came with. The GT40 heads have 160cc intake ports, 1.84/1.54 valves, and 65cc chambers, while the P heads got 1.94/1.60 valves.
Old 04-23-2008, 12:06 PM
Thank you for clearing that up. The famed explorer heads are "p" aren't they?
Old 04-23-2008, 01:00 PM
Conanski's Avatar
Quote:
The Explorer got both actually...
Old 04-23-2008, 01:17 PM
BEWOLD's Avatar
BEWOLD BEWOLD is offline
BEWOLD is starting off with a positive reputation.
Quote:
I was just about to correct you on the valve sizes, then you just did it yourself by posting that casting info. GT-Ps (97-00 explorer) have smaller exhaust valves than regular GT-40s, but flow more, showing they have better velocity. Oh, and intake ports I believe are only around 145-155cc same as the standard 40s, maybe 160 is an advertised number? But better than the E7TEs 124cc.
Old 04-23-2008, 01:21 PM
wow. the E7's only had 124cc on the intake. ouch. that helps put the GT40 and the World Jr's into perspective. thanks!
Old 04-23-2008, 01:50 PM
Conanski's Avatar
Quote:
Yeah.. I remember reading that somwhere too, could have been one of the Ford performance books I have at home. The chart also shows a range of combustion chamber sizes for all the heads, which is accurate as I'm sure there were more than 1 engine plant producing parts at any time, and tolerances vary depending upon the amount of maching the castings got.
Old 04-23-2008, 04:06 PM
Thanks for posting that cylinder head data Conanski. One usually sees only the old data from the start of small blocks in 1962 until the late 70s. The data you posted almost looks like official Ford tables. Where does it come from?
I see it is missing some items like the E6SE and pre 85 351W. Any idea if a comprehensive listing of this kind of stuff exists?
Old 05-05-2008, 04:52 PM
treading's Avatar
treading treading is offline
treading is starting off with a positive reputation.
I have a question. Would 96 explorer GT40 heads fit on a 93 5.8L EFI
Old 05-05-2008, 07:12 PM
petes79f150 petes79f150 is offline
petes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to beholdpetes79f150 is a splendid one to behold
See post #4. The 302/5.0 heads use 7/16" head bolts, the 351/5.8 uses 1/2" bolts. The smaller holes can be drilled by a machine shop so they can swap to the 351; special step "reducer" washers are available to make the 351 heads work on the 302.
Pete
Old 05-05-2008, 08:31 PM
treading's Avatar
Thanks
The reason I ask is that if I go to Jegs or Summit for gt40 heads they want megabucks where as if I go to Rockauto and look up stock heads for the 96 explorer I get:
<TABLE class=main style="BORDER-RIGHT: 2px groove; BORDER-TOP: 2px groove; BORDER-LEFT: 2px groove; BORDER-BOTTOM: 2px groove; BACKGROUND-COLOR: white"><TBODY><TR class=part0 id=table379part0><TD><TABLE class=parts><TBODY><TR><TD class=left><TABLE class=layout><TBODY><TR><TD>MARSHALL Part # H3195 {Remanufactured}
CAST# F3ZE, F1ZE, HAS 3 BARS ON FRT OF HD WITH 1/2" HD BOLT HOLES. W/O THERMAL EMMISSION HOLES IN HEAD</TD></TR><TR><TD>* Non-stock item--shipping delayed up to 7 business days
Now somebody said that the F1ZE heads were gt40s
</TD></TR></TBODY></TABLE><TD class=right></TD></TR></TBODY></TABLE></TD><TD class=center id=node379part0price>$195.79</TD><TD class=center id=node379part0core>$100.00</TD><TD class=center id=node379part0total>$295.79</TD></TR></TBODY></TABLE>
GT40P heads tonka toy72 1987 - 1996 F150 & Larger F-Series Trucks 2 10-06-2014 01:50 PM
gt40 and p heads same bolt pattern as my stock heads jrp79 1987 - 1996 F150 & Larger F-Series Trucks 9 08-24-2013 06:17 PM
GT40P heads on F150 my93 1987 - 1996 F150 & Larger F-Series Trucks 4 03-28-2012 09:38 PM
GT40p head on F150 my93 1987 - 1996 F150 & Larger F-Series Trucks 2 03-25-2012 01:07 PM
Performance heads Gt40, E7TE???? gov2mod 1978 - 1996 Big Bronco 1 05-28-2005 12:08 PM
Tags
351w, 40, cast, chart, cylinder, f3ze, flow, ford, gt, gt40, head, heads, identification, iron, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
