I'm currently researching, planning, and budgeting a speed density to mass airflow conversion for my 94 F150 5.8L with E40D. So far from what I have found is that a Mustang MAF ECC won't work with the E40D and my best bet would be swapping parts from a 95-96 truck with the same engine and tranny.
That or drop 1500 bucks on a conversion kit
Anyone have some advice, tips, or links that can help me on this conversion?
Any help would be great, thanks!
Luckily my K&N intake will save me from using the ductwork, do you know if the engine harness will be a direct plug in or will I have to cut and splice it in?
Retarded me I don't know if I can edit my post (lol) but I have found several possible donor vehicles in my local area. However, none of them are trucks with the 5.8L. One truck has the straight 6, another the 5.0L, and even a Thunderbird with 5.0L HO. The straight six is auto but the tranny was pulled out already. The Truck 5.0L was a E40D, and I'm not sure what the Thunderchicken had.
Anyone know if any of these vehicles could fit the bill?
A MAF 5.0 truck computer and harness for an E4OD will run a 5.8, it'll just need a trip around town to learn the motor's requirements every time the battery is disconnected.. which shouldn't be very often. Forget about a 6-cyl setup it can't run an 8-cyl, or the T-Bird, it didn't use the E4OD tranny and that's the 1 thing you absolutely got to have compatability with.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
