Are you using E-85 in your flex fuel engine????
If so, then expect lower mpg.
If not, also consider putting the flex fuel sensor on your suspect list for check out.
I'd also check the O2 sensors switching speed. A whiff of coolant won't do them any good.
Also with 90K on them, they might be lazy, so check their switching speed out with a scantool.
Sounds like you have/had several issues, all of which would likely affect driveability.
Let us know how it goes.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles, but trifles make perfection & perfection is no trifle (Ben Franklin)
Your signature is a sign of a job completed, autograph your work with excellence
