Quote:
Originally Posted by kermmydog
First off an 85 F350 with a factory 460 came with an in-tank fuel pump & sending unit as shown above. Second if it is factory there should not be a catalytic converter over 8600#.
My guess is the 460 is not the stock 460. It must of come out of an older truck or at least the timing cover is older. If my memory is correct 1984 F350s & up had electric pumps in tank, even on the carbed 460s.
Sorry, Ford Motor Company doesn't agree with you.
The parts catalog shows
four 460 sending units for 1985/86, and
two for 460's in 1987.
These are just the senders, no pump.
Examples:
E7TZ-9275-C = 1987 F250/350 351 or 460 w/155" or 168.4" wheelbase-use with 19.5 gallon aft axle steel tank.
E5TZ-9275-JA = 1985/86 F250/350 with 351 or 460 w/ 133" / 155" / 168.4" wheelbase-use with dual line mid-ship tank.
The 1985/86's use the SMALL sender gasket, which is the same gasket that fits cars from 1960 thru mid 1980's, and 1967/79 F100/350's except with the incab tank: COAF-9276-A.
The 1987's use the LARGER sender gasket: E1VZ-9276-B.
Info source: 1980/89 Ford Light Truck Parts Catalog / Section 90 / Pages 31 & 32.
Since most Ford dealers still have this catalog, it's fairly EZ to go to a dealer, give him those refs...and...take a look-see.
