Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 09:26 PM
hooksetz's Avatar
hooksetz is starting off with a positive reputation.
blowing through the intake ,please help
shes a 7.3idi diesel in an 88 f250 & shes blowing out instead of sucking in,any ideas,it wont start at all.
  #2 (permalink)
Old 04-17-2008, 09:55 PM
cookie88's Avatar
cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold
Welcome to FTE!!!
I've only run across that once before. That truck had a couple of broken rockers and bent pushrods. Pretty easy fix.
Other than that....I couldn't even guess.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
  #3 (permalink)
Old 04-17-2008, 10:36 PM
hooksetz's Avatar
thank you very much,now i have somewhere to start anywho.hopefully thats it,but im pretty new to diesels so you are a big help thanks a whole lot.
  #4 (permalink)
Old 04-17-2008, 11:18 PM
PLC7.3 is gaining momentum as a positive member of FTE.
Visit........ TheDieselStop.Com - www.ford-trucks.com
It shows what is probably going on with your valves due to worn guides..... right now your not hitting the piston with the valve, but how soon it does is measured in thousand of an inch.....
__________________
93 F250 SC 4x4 E4OD 355LS
  #5 (permalink)
Old 04-18-2008, 08:42 PM
hooksetz's Avatar
pulled all the rockers & push rods they're fine no damage at all,tomorrow im gonna attempt pressure test,any ideas?
  #6 (permalink)
Old 04-18-2008, 09:35 PM
OK those rockers and pushrods need to go back in the same places they were removed from.......cardinal rule
What type of pressure test...... compression, leakoff....?
Best check is to depress the valve stem into the head about 1/4" then attempt to wiggle the stem/spring....... you will find the bad ones pretty easy.
__________________
  #7 (permalink)
Old 04-18-2008, 10:21 PM
hooksetz's Avatar
i wrapped & marked each one they are back in original position,i'll do that stem wiggle test in the morning,and from there i thought my buddy had a gauge that would do a diesel but he doesnt,so until monday i'll just be trying to check visually and by hand what i can.
  #8 (permalink)
Old 04-19-2008, 12:11 AM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
Take the glow plugs out and use a rubber tipped air blow nozzle and charge each cylinder. See if you have any air going anyplace it shouldn't. Make sure the truck is out of gear and stay clear of the fan and the other goodies that spin and have no conscious. You may have a floated lifter or two.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #9 (permalink)
Old 04-19-2008, 12:24 AM
Karl Keicher's Avatar
Karl Keicher is starting off with a positive reputation.
What was it doing right before this problem developed?
  #10 (permalink)
Old 04-19-2008, 08:31 AM
hooksetz's Avatar
the truck was just traded for ,i swapped an old bronco mud truck for it,the guy i got it from said he just thought it was the batteries,i figured even if i had to put a motor in it id have me a really nice truck,but id like to try all options on gettin this thing going first (she is cherry,all for the not starting part)
  #11 (permalink)
Old 04-19-2008, 11:39 AM
From previous experience, I would say you have some bad valve guides and or seats, and possibly some burned or broken valves. If you wind up having to remove the heads, do yourself a favor and COMPLETELY rebuild them with all guides and seats and valves. You may be better off spending the money on new heads unless you can do them yourself. If it turns out you have timing issues ( not likely) you may want to start by yanking the engine
  #12 (permalink)
Old 04-19-2008, 12:20 PM
hooksetz's Avatar
heads are coming out next,hopefully they can still be reused,i'll definately be dropping them off for a valve job if that turns out to be the only damage.
  #13 (permalink)
Old 04-19-2008, 12:33 PM
A hint for head removal-when removing the head bolts, the lower bolt in the back on each side will probably have to remain in the head until it is pulled off the engine because it wont clear the heater box and firewall. Just remember to put them back in before re-installing. Just had a head gasket job for a guy that thought he didnt need to re-install those 2 bolts! Anyway-good luck!
  #14 (permalink)
Old 04-20-2008, 09:44 AM
hooksetz's Avatar
i did a leak down test yesterday, cylinder 1 blew out the exhaust,4 blew out the intake,no need to go any further i guess. heads will start coming out today.the good news is no air blew into the block that i could tell.
  #15 (permalink)
Old 04-20-2008, 09:53 AM
hooksetz's Avatar
oh yeah, i had the rockers off so the valves should have been shut ,right?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
