Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 04-20-2008, 10:03 AM
Diesile is starting off with a positive reputation.
Right!!!!!!
  #17 (permalink)
Old 04-20-2008, 12:40 PM
Karl Keicher's Avatar
Karl Keicher is starting off with a positive reputation.
You will probably find a bad guide and or seat-when doing the job it is reccomended that you replace ALL the exhaust valves and guides to avoid further problems. Low sulfer diesel will eat up the old ones so do right, do it once and then drive the hell out of her!
Good luck!
  #18 (permalink)
Old 04-20-2008, 01:18 PM
hooksetz's Avatar
hooksetz is starting off with a positive reputation.
thanks, all u guys have really been a big help,ill keep ya updated as to the process of going from a gasser to a diesel freak.
  #19 (permalink)
Old 04-20-2008, 02:08 PM
Well dont be intimidated by the diesels-they just require patience and a little thought, but are basically pretty simple animals that will give you alot of miles! Good luck!
  #20 (permalink)
Old 04-20-2008, 02:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Quote:
Don't forget the stronger back to lift the parts.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #21 (permalink)
Old 04-20-2008, 07:12 PM
cookie88's Avatar
cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold cookie88 is a splendid one to behold
Yeah...those heads are heavy!
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
  #22 (permalink)
Old 04-20-2008, 07:54 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
.....95 pounds each if memory serves. Almost as heavy as the crank.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #23 (permalink)
Old 04-20-2008, 09:19 PM
Even heavier when you set them back on the engine and discover you didnt put that back head bolt in before hand!As my hero tim allen would say " oooooooooohhhhhhhhhh noooooooooooo-RRR"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
