Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 07:19 PM
cdrmotorsports's Avatar
cdrmotorsports is gaining momentum as a positive member of FTE.
Clear Powder Coat?
Is there a clear powder coat I could put on wheels to protect them? I'm looking at a set of wheels that have black painted centers and a stainless lip. I don't know if they'll hold up in the winter, so I want to protect them the best I can. Would powder coat adhere?
__________________
2001 Ford F-250 Super Duty 4X4 Crew Cab Shortbed Lariat 6.8L V10
Check Out My Gallery:
http://www.ford-trucks.com/user_gall...?userid=289268
  #2 (permalink)
Old 04-17-2008, 08:45 PM
96F250tat's Avatar
96F250tat is starting off with a positive reputation.
Yes there is such thing as clear powder coat. But you just cant powder coat over anything, especially regular paint. Im pretty sure the paint on those wheels wont hold up to 400 degrees, which is the temp the powder needs to cure, so you're not gonna be able to clear over reg paint. You are gonna need to sandblast the wheels. Then you can put whatever color powder coat on you want and then you can put clear powder on the wheels. Powdercoating the wheels then putting clear powder on the wheels should hold up very well.
  #3 (permalink)
Old 04-18-2008, 09:55 AM
spinella is starting off with a positive reputation.
also keep in mind that powdercoating is thick so make sure holes for lugs are not treated with it.
__________________
2000 f350 v10 lariet 4wd
35"x12.5x16.5 BFG
superlift leveling kit
  #4 (permalink)
Old 04-18-2008, 11:51 AM
BChance's Avatar
BChance is starting off with a positive reputation.
Look at Eastwood Company, they have made powdercoating kits pretty affordable, and have a number to a tech guy that specializes in powdercoat.
Eastwood Company - HotCoat Powder Coating Gun
  #5 (permalink)
Old 04-18-2008, 09:16 PM
Thanks guys. What about a clear coat?
__________________
  #6 (permalink)
Old 04-18-2008, 09:55 PM
96F250tat's Avatar
What do you wanna know about clearcoat?
  #7 (permalink)
Old 04-18-2008, 09:57 PM
fivonut is gaining momentum as a positive member of FTE.
Quote:
Also, clear powder coat has been known to cure with a yellowish tint.
  #8 (permalink)
Old 04-18-2008, 10:02 PM
96F250tat's Avatar
Quote:
Yes, exactly. It has also been known to make the primary color dull, especially chrome. I Found out the hard way!
  #9 (permalink)
Old 04-19-2008, 04:42 PM
Could i put a clearcoat ona wheel with a stainless lip? What does clear coat adhere to?
__________________
  #10 (permalink)
Old 05-22-2008, 01:46 AM
archangel is starting off with a positive reputation.
Quote:
Originally Posted by cdrmotorsports View Post
Could i put a clear coat on a wheel with a stainless lip? What does clear coat adhere to?
It will adhere to any clean metal surface (no oil) that will conduct electricity and survive 400 degrees without weakening.
The surface does not need to be blasted, so polished rims will do well, just be sure they are clean.
Also, the black center can be powder coated black, and the rest of the rim clear powder coated clear.
__________________
Gray 1991 F250 standard cab, 7.3, E4OD, 3.55:1, stock wheels and tires.
Verified 19 mpg city taking off slow as hell the shutting down at red lights, and with the radiator grill blocked flush, no bed cover, "drag shoot" mirrors on I get 24 mpg at 50 to 55 mph on the freeway empty!
However, with a bed cover, no mirrors and Hydroxy
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
