Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 07:07 PM
chaser1602 is starting off with a positive reputation.
Headlights on parking lights out
I just noticed this.Is this what yours does?
  #2 (permalink)
Old 04-17-2008, 07:13 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
Tis the 1960's.
All the trucks (and cars) back then did the same thing.
Turn the headlamps on, the parking lights turn off.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #3 (permalink)
Old 04-17-2008, 08:11 PM
Quote:
Originally Posted by NumberDummy View Post
Tis the 1960's.
I have had my truck for how long? and just NOW noticed this when I did the headlight upgrade.
  #4 (permalink)
Old 04-18-2008, 08:47 AM
64F-100's Avatar
64F-100 is starting off with a positive reputation.
Wow! I didn't know it was supposed to do that...I just thought the wiring in my slick was screwed up!
__________________
Balz
1964 F-100 V8 4spd
1987 Thunderbird Turbo Coupe
2003 Thunderbird Roadster
1974 Ford LGT 145 Garden Tractor
1987 Ford LGT 18H Garden Tractor
  #5 (permalink)
Old 04-18-2008, 05:43 PM
I was getting ready to tear mine apart to fix it!!!!
  #6 (permalink)
Old 04-18-2008, 06:12 PM
airharley's Avatar
airharley is gaining momentum as a positive member of FTE.
If anything you may want to install a headlight relay system to cut down on the amount of power loss the headlights see running through the switch. Then you can have the running lights on at the same time as the headlights. There are a few kits premade out there. But if you are handy with wiring then making your own system is ubber simple and cheaper by $90.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
'03 F150 Shortbed 5.4L/4R70W/3.55 LS
Author of the disc brake article for 57-64 F-100's
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
