Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 06:30 PM
Pacdaddy is starting off with a positive reputation.
'65 vs. '66
I've read quite a few posts regarding many things and I want to understand everything I can about my truck before I go to tinkering TOO much.
Other than suspension what are the main differences between my F250 and an F100? I want to be able to know what parts can interchange and what parts cannot.
Also, I saw some pics of sllt96xlt's interior. I like the painted dash. My truck has a pad with ONE crack. If I were to pull the pad off should it be as simple as cleaning it up and shooting it with some paint?
  #2 (permalink)
Old 04-17-2008, 06:42 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
You don't need to paint the dash...it's already painted...from the factory.
You like the painted dash? There was a padded dash on on sllt96xlt's truck, it's been removed. That's why those horizontal mouldings are there ...to retain the lower portion of the padded dash.
Those mouldings were only installed on the dash for that reason.
No padded dash originally = no mouldings.
Now you know what's under your padded dash, all the dashes were painted, the padded dashes (if so equipped) were added later on the assembly line.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #3 (permalink)
Old 04-17-2008, 06:45 PM
Lemme grab a screw driver!
Thanks, ND!
I've been looking for dropped I Beams for my truck. I only find drop I beams for F100. Will they interchange? I just don't know enough about the differences in the two....sorry...
  #4 (permalink)
Old 04-17-2008, 06:54 PM
Ford Parts Guru
1) C6TZ-3006-C .. Right Axle (I-Beam)
1) C6TZ-3007-C .. Left Axle (I-Beam)
2) C5TZ-3A360-A .. Radius Arms R/L
Fit: All 1965/71 F100/250 2WD.
Same: I-Beams, radius rods, radius rod brackets, tie rods, drag link, front coil springs.
__________________
  #5 (permalink)
Old 04-17-2008, 07:29 PM
camperspecial65 is gaining momentum as a positive member of FTE.
I thought 1/2 and 3/4 ton I Beams were different since the 3/4 tons have a bigger king pin...
- cs65
  #6 (permalink)
Old 04-17-2008, 07:47 PM
I need to know...????
ALso, what would be the difference in a truck with a straight metal dash and one with a pad? Meaning, would a pad denote custom cab? Do I need to get the warranty number for ya'll to decode?
  #7 (permalink)
Old 04-17-2008, 08:22 PM
gangstakr's Avatar
gangstakr is gaining momentum as a positive member of FTE.
When removing the dash pad, you want to use a putty knife. Have a couple on hand 2" and a 4" it's easier. Some of the pads are glued down pretty good, especially around heater vent holes and speaker holes. If your saving the pad take windshield out. Either way take your time taking pad off, try not to scrape dash. Once pad is removed, you'll have a lot of glue to clean up not sure what would work best for removal of glue.
__________________
Staying low for now
64 lowered longbed
Robert
  #8 (permalink)
Old 04-17-2008, 08:31 PM
matt2491's Avatar
matt2491 is new and has a neutral reputation at this point.
I can't tell you a definitive answer, but my '64 Custom Cab doesn't have a pad, nor does it look like it used to have one or one was removed...
  #9 (permalink)
Old 04-17-2008, 10:21 PM
sllt96xlt is starting off with a positive reputation.
of course i do not know what mine looked like during it's whole life. it definately looks like it never had a dask pad but ND says the molding is there for it and i do believe him. i like the way my truck looks now so i do not plan to add one even if it came with one. next time i'm at my truck i plan to take the seat covers off and look at what is underneath.
__________________
1965 F250 Custom Cab
1972 F250 XLT Ranger, to be donor truck.
  #10 (permalink)
Old 04-18-2008, 12:59 AM
Ford Parts Guru
Quote:
Glue removal, also bumper stickers, 3M double sided tape, etc.
ACRYSOL (made by Kent Industries), available at automotive paint supply stores.
Use a plastic putty knife...less chance in scratching the dash.
__________________
  #11 (permalink)
Old 04-18-2008, 01:14 AM
Ford Parts Guru
Quote:
- cs65
1965/71 F100 = front axle parts list 30.2A: C6TZ-3006-C & C6TZ-3007-C .. R/L I-Beam / C5TZ-3111-C .. K/P Kit (1965) / C8TZ-3111-A .. K/P Kit (1966/71).
1965/71 F250 = front axle parts list 30.2C or D: C6TZ-3006-C & C6TZ-3007-C .. R/L I-Beam / C5TZ-3111-C .. K/P Kit (1965) / C8TZ-3111-A .. K/P Kit (1966/71)
Any more questions?
1965/71 F100's use different spindles than F250's do, but the king pins are same-o same-o.
__________________
  #12 (permalink)
Old 04-18-2008, 01:26 AM
Ford Parts Guru
Quote:
Originally Posted by sllt96xlt View Post
of course i do not know what mine looked like during it's whole life. it definately looks like it never had a dash pad but ND says the molding is there for it and i do believe him. i like the way my truck looks now so i do not plan to add one even if it came with one. next time i'm at my truck i plan to take the seat covers off and look at what is underneath.
1) C5TZ-8104332-A .. R/Side Instrument Panel Pad Retaining Moulding
1) C5TZ-8104333-A .. L/Side Instrument Panel Pad Retaining Moulding
8) 379852-S3 .. Clip
__________________
  #13 (permalink)
Old 04-18-2008, 01:32 AM
Ford Parts Guru
Quote:
C5TZ-8104290-BFA .. Padded Dash-Black
Fits: 1965/66 F100/1100
1961/64's did not offer/come with padded dashes.
__________________
  #14 (permalink)
Old 04-18-2008, 01:43 AM
Ford Parts Guru
Custom Cabs (1965/66) came with padded dashes as standard equiptment.
Padded dashes were optional on (1965/66) Standard Cabs.
There's nothing in the Warranty Number (VIN) that tells whether the truck is a Standard or Custom Cab, or has the Ranger Package.
The ONLY way to know if the truck (originally) was a Standard or Custom Cab or had the Ranger Package is by the BODY CODE.
If the first digit of the Body Code is a number, it's a Standard Cab.
If the first digit of the Body Code is a letter, it's a Custom Cab.
Ranger Package: The first digit of the Body Code is a letter. Rangers used 3 specific letters (1965: F, G, H / 1966: T, U, V) not shared by Custom Cabs.
__________________
  #15 (permalink)
Old 04-18-2008, 03:11 AM
tbm3fan's Avatar
tbm3fan is gaining momentum as a positive member of FTE.
[quote=NumberDummy;6053742]
Any more questions?
[quote]
Look out, he's on a roll!!!
__________________
Mike
1968 Cougar 302-4V
1968 Mustang 289-2V
1967 Parklane 410-4V
1965 F-100 360-2V
1943 USS Hornet/1945 TBM3E Avenger
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
