Running a 94 f 350 7.3 cube van and a trans seal is gone . Happened last Oct and I used the Lucas trans fluid and it held until this week . Now I need a e4od trans and the more questions I ask the more confused I am . I have found a 21 k rebuilt out of a 94 7.3 supercab half way from me across Canada. Fellow at the salvage yard ran my present trans id numbers and said I have the wrong tranny in now and he has the right one to fit.
One problem I have is the salvage yard says the F 3up-ea
tag off mine says it is for a 93. The tag on his rebuilt trans is F4up (F) A if I recall correctly.
Question I have is there a big difference in these trans and will the 4up work in replace of the 3up?. Talked to a trans tech here and he said I have to make sure to buy a 94 or lower and it will work with present solinoid pack.
Called Ford down here and was told it is the difference in the gear ratio and I should replace the exact one the
truck calls for. Any help on this is very appreciated as I want to be sure before I have a trans shipped across Canada. Any other info I am missing I will post if needed asap.
Dumped two jugs of Lucus in today for a "another " quick fix and haven't had the nerve to turn it over until Friday am. Sorry long winded here but just really confused on which tranny is the right one. Thanks for any help that is offered. Phil
ps this are the #'s of the present in truck e4od
F3up - EA
PRA JB3
00024502
BD-3k20
