Not a good update. Even though I disconnected the injector, fuel still getting in to the oil. When I did oil change, I left it just bellow the minimum mark, and today it is all the way up to maximum. So, now, I think there is something else going on with it, other then #1 cylinder.
Will keep updating, as things change, it may help someone else in the future.
__________________
Vitaliy - legal immigrant, naturalized citizen and call it home.
Sacramento, CA
95 Ford Super Duty 7.3L TD with about 300K miles.
99 Ford F-450 7.3L TD with over 330K and still drives.
BEST vehicle ever owned.
2003 Ford F-550 6.0L with 165K miles and most problems. HELP!!!
OK, get oil dye, put it in the secondary fuel filter housing. Remove both valve covers, insert paper towels in the drain holes below each injector. If you can power up the fuel pump with a diagnostic tool, it would be better, but if not, turn the key on (it'll only run for 20 seconds or so). Using a black lite, look for fuel leakage from one of the injectors. The paper towels will also show any fuel leakage.
__________________
ase master tech--fmc master tech81 f150--300 4x4
Do you think it is bad o-ring in one of the injectors and it is shooting fuel out in to heads?
__________________
Sacramento, CA
I had an Injector clamp get loose on #1 cylinder on my 2003 6.0. The injector slipped up just enough to leak diesel by and flow in to the crankcase. Every time I turned the key on the electric fuel pump was pumping diesel in to the crank case. You can pull the glow plugs out one at a time and turn the engine by hand and find out which cylinder is leaking fuel by. If that is the problem.
I am my own mechanic and I changed injectors more then once, so I do not see the problem with that.
You may want to look over the shop manual in the link attached just to make sure the procedure you followed for the previous injector replacement (and the one to follow if you find that it is in fact a leaking o-ring) is what is recommended.
Please keep us informed of what you find so that we can all learn from it. It is very nice to have certified tech's here to guide us through our problems. Make sure you give rep points to those that help you get this resolved!!
(thanks to vloney and others)
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Hey, Mark, thanks for the link. Also, you told me about o-rings in the beginning, but it was pretty hard to believe, as I changed full set of injectors only about 4k miles ago. Will work on it Saturday and will post more updates.
__________________
Sacramento, CA
Update (bad news)
Did, what you have said, 7 cylinders were leaking. Replaced o-rings and copper gaskets on all 8 of them and torque to 25 lbs - no help. Same 7 are leaking. Anything else I can do, may be just buy some thicker Napa o-rings and install them?
__________________
Sacramento, CA
You said that you had been doing your own mechanic work, and your torque wrench wasnt well used. If improper torque has been used in previous injector installation, the holddown bolts can be stretched to the point that they wont secure the injectors in the sleeves, creating leaks. From your description, its a problem thats common with all of the injectors. Its very unlikely that you have all of them defective, or all of the sleeves bad. If you dont use a torque wrench every time, with the proper t40 socket (with a long shank) you can be causing more damage than is repaired.
__________________
