Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 04:51 PM
64shrtbed's Avatar
64shrtbed is starting off with a positive reputation.
250 into a 1964 F100?
Would it make sense to swap a 250 I6 with auto trans from a 1973 Maverick into a '64 F100? Can I use 300 mounts? Will it fit in there OK ?
As always, Thanks for the info.
Shrtbed
  #2 (permalink)
Old 04-18-2008, 03:51 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
Originally Posted by 64shrtbed View Post
Would it make sense to swap a 250 I6 with auto trans from a 1973 Maverick into a '64 F100? Can I use 300 mounts? Will it fit in there OK ?As always, Thanks for the info.
Shrtbed
NO!
Waaay too underpowered an engine for an F Series truck.
Nothing but passenger cars ever used the 250 I-6 engine.
There's no motor mounts to install this engine in an F Series truck.
There's enough room in a F Series' trucks engine compartment to mount two 250's side by side.
Is it a 250? It could be a 200. Both engines look identical, and both were used in Mavericks/Comets.
200: the stroke is 3.13" / 250: the stroke is 3.91" / the bore is the same: 3.68"
Some early Bronco's (1973/74) and Econolines (1969/74) used 200's, but these models are gutless wonders.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #3 (permalink)
Old 04-18-2008, 04:06 PM
64shrtbed's Avatar
I thought it wouldn't be a good idea power wise, I actually already have a 300 I am starting to build for it. I just saw that 250 runner and I got to thinking.........
  #4 (permalink)
Old 04-18-2008, 06:13 PM
airharley's Avatar
airharley is gaining momentum as a positive member of FTE.
Well the good thing is that you went straight for a reality check then the wallet.
__________________
Mark J. Covill
"I'm not handicapped, I'm handicapable!"
'64 F-100 Shortbed 460/C-6
'03 F150 Shortbed 5.4L/4R70W/3.55 LS
Author of the disc brake article for 57-64 F-100's
  #5 (permalink)
Old 04-18-2008, 09:23 PM
64shrtbed's Avatar
Don't even really have to use the wallet. The '64 is getting the 300 and three on the tree from my '68 F100 after I rebuild it and then I am going to put a 302/T5 in my '68.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
