The best way to figure out the offset you need is to actually measure with your wheel off and determine how much backspacing you can have. Backspacing and offset go hand in hand. There are companies that sell tools to do this or yoou can do it the old fashioned way with straight edges and a tape measure. Set a straight edge against your drum (or rotor) face, then measure from that to where the inside wheel lip will be. Remember to add about an inch to each side for tire bulge. If this measurement is about four inches and you want to run an 8" wide wheel than your offset is 0. Then measure from the same spot to the bed or fender to check clearance the other way. You'll want to make sure your truck is at it's natural ride height when taking these measurements. Hope I didn't confuse you and good luck!
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'01 F250 CC SB 4X4, 7.3 powerstroke, 6-sp manual
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
