old kero
Old 04-17-2008, 07:50 AM
C350CREW's Avatar
C350CREW
C350CREW is offline
old kero
hey guys, got some old kero, from 3yrs to 6 mo, any recomendations on how to blend to use this stuff up?? kero is just better deisel, right??
thanks ahead of time
Old 04-17-2008, 09:28 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Kerosene is fine for your diesel.
It need some lubrication supplement because all of the natural lubes have been removed.
Old 04-17-2008, 09:48 AM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
If it's been sitting that long, especially if it's been in an unsealed container, some of the lighter hydrocarboins will have flashed off. That's no big deal, but I'd make sure to blend it with fresh diesel at least 50/50.
Also, if it's in a large contianer like a drum or barrel I wouldn't stir it or pull from the bottom of the barrel. There will probably be some sediment down there that has settled out naturally.
How much of this stuff do you have?
Old 04-18-2008, 08:52 AM
C350CREW's Avatar
C350CREW
C350CREW is offline
I have about 15-20 gal. all of it has been in sealed 5 gal cans. couple of buds had from when they used kero heaters. so just mixing with fresh diesel and some lube additive should cover it. sweet thanks!!
Old 04-18-2008, 09:01 AM
seventyseven250
If it's been in sealed cans then it sounds like you won't have to worry about the things I mentioned. I say just throw once can in per fill-up and you will be good to go.
Walleye Hunter
02-14-2016 09:15 PM
gfw1985
Garage & Workshop
09-28-2015 05:23 AM
firewood truck
46
05-31-2012 08:41 PM
Phat02
Appearance & Dress-Up
29
01-07-2006 03:42 PM
PAUL_2
07-11-2002 04:06 PM
Quick Reply: old kero
