Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-17-2008, 07:50 AM
C350CREW's Avatar
C350CREW C350CREW is offline
Garage is empty, add now
C350CREW is starting off with a positive reputation.
old kero
hey guys, got some old kero, from 3yrs to 6 mo, any recomendations on how to blend to use this stuff up?? kero is just better deisel, right??
thanks ahead of time
  #2 (permalink)
Old 04-17-2008, 09:28 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Kerosene is fine for your diesel.
It need some lubrication supplement because all of the natural lubes have been removed.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 04-17-2008, 09:48 AM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.seventyseven250 has a great reputation on FTE.
If it's been sitting that long, especially if it's been in an unsealed container, some of the lighter hydrocarboins will have flashed off. That's no big deal, but I'd make sure to blend it with fresh diesel at least 50/50.
Also, if it's in a large contianer like a drum or barrel I wouldn't stir it or pull from the bottom of the barrel. There will probably be some sediment down there that has settled out naturally.
How much of this stuff do you have?
__________________
2005 F150 SuperCrew Lariat
  #4 (permalink)
Old 04-18-2008, 08:52 AM
C350CREW's Avatar
I have about 15-20 gal. all of it has been in sealed 5 gal cans. couple of buds had from when they used kero heaters. so just mixing with fresh diesel and some lube additive should cover it. sweet thanks!!
  #5 (permalink)
Old 04-18-2008, 09:01 AM
If it's been in sealed cans then it sounds like you won't have to worry about the things I mentioned. I say just throw once can in per fill-up and you will be good to go.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
