Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 08:49 AM
budthedog is starting off with a positive reputation.
Question for the experts
We have decided to buy a motor home. There's a ton of them out there now selling pretty cheap due to the economy. I could spend around 50K for a relatively new one with low miles, but I found a 95 E350 with only 22K miles on it & in pretty good shape. It has the 7.5 (460?) engine, unnamed auto trans & a 4:10 towing axle. Of course it's past the factory warranty, but so are the newer ones. There's a very significant price difference, so I'm wondering if there were any particular issues with the 95's.
Of course I'm not really too concerned about gas mileage, none of them are gonna be like my Festiva. All I'm wondering about is if I'd be buying trouble. I've had several Ford vans & they've all been practically bulletproof so far. Thanks for any advice.
  #2 (permalink)
Old 04-17-2008, 09:42 AM
merlynr is starting off with a positive reputation.
My F250 with 7.5 has been relatively trouble free for 87K miles. Rear pinion seal leaked and replaced seal. Catalytic convertor started rattling(on the inside), so I fixed it DIY style. Other than normal maintenance this thing has been dependable. Gas mileage isn't too good, but it'll pull.
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #3 (permalink)
Old 04-17-2008, 10:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE. Mark Kovalsky has a great reputation on FTE.
Quote:
The 7.5L is the 460.
It's most likely an E4OD trans. If it has an OD OFF button and light on the end of the shifter it's an E4OD. If there is no button or light it's a C6.
The C6 is going to be a gas hog. There is no lockup or overdrive, so the engine will be SCREAMING on the freeway and don't expect over 5-6 MPG.
Most likely it's an E4OD.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #4 (permalink)
Old 04-18-2008, 03:14 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
as mark stated you will probably have the e4od
this is the only weak link in it, it is high dollar to rebuild.
if so test drive it for at least 10 miles
soft shifts are normal
best to install a shift kit to firm it up
will help trans last longer
also will want a Large trans cooler(larger than stock)
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #5 (permalink)
Old 04-22-2008, 07:02 AM
Thanks guys. We looked at it Sunday & it has the E40D. The owner said it gets 9 - 11 mpg. I didn't drive it yet, but the guy did start it & it sounded OK. I'm not in any big hurry to buy one now, with gas hitting $3.75. The wife can't seem to make up her mind for sure (imagine that) & it's OK with me since I haven't researched engines for 20 some years. A lot of the newer ones have the V-10's, are they significantly better?
  #6 (permalink)
Old 04-22-2008, 10:13 AM
Genesis is starting off with a positive reputation.
V-10
Absolutely. The V-10 has more HP and Torque and is incredibly smooth(and quiet) making it ideal for motor homes. With the newer V-10 set-up you'd also get the 4R100 transmission which is basically an improved E4OD to handle the additional torque of the V-10. The gas mileage should be about the same. Don't listen to those oh my god don't get a V-10 with these gas prices. That 7.5l is a major league gas guzzler. My V-10 van gets 1-2 MPG less than my friends V-8 and the performance difference is well worth it to me. Good luck with your decision.
__________________
2003 E-350SD, V-10, 373LS, 4R100, 3" rear lift, Diablo Tune
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
