Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 07:30 AM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
Finding and Solving Engine Vacuum Leaks
a common problem on our Ford OHV V6s with the small intake manifold bolts and questionable sealing gasket life along with the tall intake plenum causing bolt loosening with dynamic engine movement. lots of vacuum hoses that fail in the high temp. environment
Vacuum Leaks click
http://www.aa1car.com/library/fuel_trim_wellsmfg.pdf
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
