Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-17-2008, 12:07 AM
fixnair is starting off with a positive reputation.
Valve tool
Anybody know where I can get a tool for removing valves & springs from a flathead V8 Ford? And about how much does one cost?
Just started on my '52 F1 frame up.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-17-2008, 07:07 AM
kotzy is starting off with a positive reputation.
Since your working on an after 1948 engine I think a regular valve spring compressor will work. The bar was used to pull tension off the spring to pull the guide lock. Since removal of the keepers will release the pressure against that lock on the later design their removal is easier. If the guides are not worn you may as well leave them alone. kotzy
  #3 (permalink)
Old 04-17-2008, 08:08 PM
Kazoo is starting off with a positive reputation.
They seem to come up on E-Bay quite regularly. Just type in Ford Flathead and all kinds of goody's come up. The ones I have seen are usually reasonably priced.
  #4 (permalink)
Old 04-17-2008, 10:27 PM
effie_man's Avatar
Fatty driving the Flatty!
effie_man is starting off with a positive reputation.
Quote:
ya what he said
__________________
Chris
53 f100 Custom Cab
04 F150 STX 4x4
  #5 (permalink)
Old 04-18-2008, 12:39 AM
51ford fan's Avatar
51ford fan is starting off with a positive reputation.
Valve Guide Removal Tool
Click on the text above, (Valve Guide Removal Tool) to go to Speedways Site. I hope this helps
__________________
Rod 51 F1 Truck
Flathead 6
S-10 5-Speed
"Keep on Truckin"
  #6 (permalink)
Old 04-23-2008, 09:11 AM
55 f350's Avatar
55 f350 is starting off with a positive reputation.
i used a small valve spring compressor from a small engine i'll have to find the part numbers for , but it worked to change two guides and etc. with the flatty still in the truck .
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #7 (permalink)
Old 04-23-2008, 07:59 PM
Thanks for all the replies. I used the info from 51ford fan and ordered a book and the valve tool.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
