Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2008, 11:39 PM
BC Powerstroke is starting off with a positive reputation.
Best Replacement Turbo
While I am on my second turbo replaced under Ford warranty in April 2006 I may have early symptoms of sticking turbo however currently out of warranty. As I am mechanically inclined, or as much I can be for do it yourselfer, I will be attempting to do the suggested technical bulletin of cleaning the turbo myself if required.
However since I will likley require a turbo replacement in the future as I plan on keeping the truck till death do us part, I am seeking advise what turbo replacements have been the best particularly in the way of reliability and service life.
I have researched the forum but found no conclusive results that inspired confidence.
I see aftermarket vendors such as those sponsored on this forum have improved stock variable geometry turbos. But what exactly has been improved to encourage improvement or facts on actual trouble/mainteance free life expectancy.
Other options I see is fixed geomtry turbo's with waste gates, ceramic inside, water cooled and etc.
Also as I can find relatively cheap replacement stock turbos what can I do to improve the stock turbo. What specific turbo and/or parts to look for my 03 application.
Lots of information and options but what has appeared to give the best results for modestly tuned stock truck as listed in my signature. I do not care for power gains but do care for maximum life and MPG.
Greatly apreciate the help in advance.
__________________
03-6L 4x4 CC SRW 3.73 Auto
Level Kit, 35"Mickeys, 20" Wheels
4" MBRP TB, Intakes Elbow
Gauges, Oil By-Pass Oil Filter, Bilistien shocks
Dual Stabilizers, AGR Pump, Synthetics
Power Slot Rotors & Hawks Pads
Moog ball joints, energy bushings
Optimas, 24" Wipers, 2008 Diff. Cover
SCTII-Spartan tunes & EGR Block-off
  #2 (permalink)
Old 04-17-2008, 04:37 PM
ALEXVB22's Avatar
ALEXVB22 is starting off with a positive reputation.
Why don't you talk to your tune guy and see if he can wip u a tune for you to address the turbo issue? Custom tunes...
or am I an idiot as i don't fully understand your problem..
At least I tried,
Alex
__________________
05' F-350, Kingranch, Crew, Dually...
SCT X3
Afe XP Stage 2 Intake!
  #3 (permalink)
Old 04-17-2008, 04:49 PM
06F250XLTFX4 is starting off with a positive reputation.
I would go call Matt @ Spartan Tech. Have him set you up with a turbo, and maybe some injectors
__________________
2006 F250 XLT, SC, SWB, PSD, Torqshift
FX4 pkg, Tow Command pkg, High Idle Mode
- BedLocker Cover
- Line-X Bed Liner
- Westin Nerf Bar
- ISSPRO Gauges
- Fuel Pressure, Trans Temp, Pre-Turbo EGT, Boost
  #4 (permalink)
Old 04-17-2008, 05:48 PM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
BC, you should consider a non-vgt. However if you tow you might want to stick with the vgt. My next turbo will definitely be a non-vgt and I do not tow.
__________________
David, 2003 f250 centennial edition, afe, arp, itp, innovative tunes, 4" straight pipe, dieselsite coolant filter, blocked off egr cooler, quadzilla commander w/pillar mount(pos), 4.5" lift, f350 rear blocks, bilstein 5100's, 20/9 kmc hoss, 35/12.5 toyo mt, tinted tail lights, 35% front window tint..
  #5 (permalink)
Old 04-17-2008, 06:46 PM
rollerstud98 is starting off with a positive reputation.
Do we need to change anything with the programming of the truck if we go to a non vgt?
  #6 (permalink)
Old 04-17-2008, 10:04 PM
yea for sure.
__________________
  #7 (permalink)
Old 04-17-2008, 11:15 PM
tex25025's Avatar
tex25025 has a good reputation on FTE. tex25025 has a good reputation on FTE.
Yes you have to because your truck's computer will be looking for the VGT, so doing a custom tune is paramount. You don't have to worry bout towing with a non-vgt turbo, I do all the time and I would say that it is better then the vgt one. Little slower in spooling, but it doesn't take long to get it going(where the vgt comes in). Non-VGT also has fewer parts to break. Everything that you see in my siggy gets used for towing(in fact tomorrow I'll be hauling supplies from co-op back to the house with the trailer).
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #8 (permalink)
Old 04-18-2008, 01:38 AM
I do have a SCTII with Spartan custom tunes. I sent Matt an e-mail yesterday.
I have 130,000km's and seems that if this turbo is gone, and since I m out of warrnty I just do not want to fork out my pocket money for another turbo only to be in the same place 2 more years down the road.
I have a truck camper towing a boat in the summer and towing a trailer with ATV's for the fall winter hunting. So I do thing VGT is my best bet but I just need to know which VGT has been the most reliable and longest lasting.
__________________
  #9 (permalink)
Old 04-18-2008, 03:24 AM
cartmanea is gaining momentum as a positive member of FTE.
directfordparts.com lists the '03 turbo for around $900 I think.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks, 35" tires
- Off Road Tech winch bumper, powdercoated white
- SCT Xcal2 with Spartan tunes (ASE)
  #10 (permalink)
Old 04-18-2008, 07:18 AM
tex25025's Avatar
Quote:
Y is that? Only really two benefits that I can see with the VGT:
1. Use as an "jake" brake
I had that, but I don't miss it
2. Quicker initial spooling
You could go to a smaller non-vgt turbo and get that without sacrificing much in the way of horsepower.
Even if you have the newer one coated and heat treated and all that, it is still going to require more care on your end to make sure everything is working correctly. I will also say this, a non-vgt turbo is alot lighter and easier to get in and out then one with a VGT.
__________________
Fluidampner
Headstuds
FASS 150/180
  #11 (permalink)
Old 04-18-2008, 01:13 PM
3000 FPS is starting off with a positive reputation.
What I did was to get a spare turbo from ebay and keep it clean and ready togo. When my turbo starts sticking I just change it out and I am on my way. These turbos usually only need cleaning and nothing else to keep them going. I found a brand new rebuilt turbo by ford with the latest up grades to it and the gaskets in the ford box for 400.00.
I took the turbo apart to inspect it and it is like brand new. It is the exact replacement for what is already on my truck. Just another option to consider.
__________________
01 F250 4X4
05 F350 CC 4X4
Slammed 54 buick
  #12 (permalink)
Old 04-18-2008, 02:40 PM
hott-rodd is starting off with a positive reputation.
What is the part number on that turbo?
__________________
2005 F350 2WD SRW LB , with 200,000 miles and rolling. Studs, SCT and 4" silverline Turbo Back .
2000 f250 2wd , fuel in-tank and pre-pump mod, 6637 filter , SS HPX, Dp 80hp tune, 5" cannon .RIP!
  #13 (permalink)
Old 04-18-2008, 03:46 PM
adambomb's Avatar
adambomb is gaining momentum as a positive member of FTE.
JMO but some guys don't want to be switching/cleaning turbos when needed and want something that they can install and have it last for a while. this is the impression i get from the OP. i know when my turbo goes out i will either replace with a larger non vgt, if i have the money, or get a rebuilt or used stock '03 turbo because i love the sound.
__________________
2005 6.0L F350 Lariat CCLB FX4
*90hp DDP Injectors*SCTX3*ARP Studs/Racing Gaskets*Banks Techni-Cooler*FASS*AFE Intake*4" MBRP Exhaust*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18"KMC Monsters*
  #14 (permalink)
Old 04-18-2008, 04:19 PM
tex25025's Avatar
Quote:
You'll love my 64mm turbo then. I had matt's old 03 turbo on my truck for awhile before I got this one. While you have to get up to about 30 for it to start whistling, it will last all the way to highway speed and be screeming by then if you have it straightpiped. I can't tell you how many people rolled up their windows with the new turbo vs. the old 03 I had(unless i was going thru a subdivision then the 03 turbo wins).
__________________
Fluidampner
Headstuds
FASS 150/180
  #15 (permalink)
Old 04-18-2008, 05:48 PM
Quote:
Motor craft number 5C3Z 6K682-A
or 5C3Z 6K682-AA
Garret number GT3782VA
__________________
01 F250 4X4
05 F350 CC 4X4
Slammed 54 buick
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
