Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2008, 08:37 PM
scottie2hottie's Avatar
scottie2hottie is starting off with a positive reputation.
double roller or single roller timing chains?
Ok I've been given both sides of the story here, and of course I'm just going to get more opinions, BUT which is better, single or double roller? In my experience I've never had anything but good luck with single rollers, so why switch now? but last night a buddy told he'd never tear one down with out putting a double roller back in. What is ya''s opinions?
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
1994 F350 "Possum"
1982 F250 "Amos Moses"
1975 F250 "Mean Green"
Quote:
Originally Posted by CMNZ59
Horsepower is how fast you hit the wall, torque is how far you push the wall once you hit it
Proud to be an OHIO BOY
  #2 (permalink)
Old 04-16-2008, 10:01 PM
tim.moman is starting off with a positive reputation.
The double roller will have less stretch for better cam control. But I have seen some (cheap) double rollers stretch horribly too.
  #3 (permalink)
Old 04-18-2008, 10:01 PM
doug1222556 is starting off with a positive reputation.
Single rollers suck, double rollers suck, at least get a true roller or a gear drive if you are going to upgrade. I don't think double rollers are much better than single, and you get what you pay for. If you want a decent roller at a budget price get a Cloyes "Street True Roller" which has a true roller chain, but less than bullet-proof gears.
  #4 (permalink)
Old 04-18-2008, 10:23 PM
brh1969 is starting off with a positive reputation.
Gear drives suck.Use the double roller and dont worry about it.
__________________
1977 F250 Super Cab Trailer Special 460 C-6
2002 F250 PSD
  #5 (permalink)
Old 04-18-2008, 11:15 PM
Quote:
O.K. - I'll be the first to admit I'm no expert, and rely on second hand info a lot, but I'm ready to learn something and would like to know the reasoning behind your statement, and will start off by providing mine. Double rollers are just that- 2 stock roller timing chains compressed into one and subject to all the same stretch problems as one, ( although a little more solid, due to the 2to 1 factor). True rollers not only have twice the rollers, they actually "roll" reducing wear and freeing up a little friction in the process, and are more reliable and have more longevity than double rollers and don't cost much more. Gear drives are deadly accurate in the timing department(zero stretch), and are stronger than chains.
  #6 (permalink)
Old 04-21-2008, 08:54 AM
I did install a gear drive that sucked once. Did not think it was possible til then. The kid wanted to hear the gears and bought a "Noisy" cheap gear set. Let the cam move 6.5 degrees. Pain to dial the cam in and it did no better than a chain at holding the cam. wtf??? So maybe just cheap gear drives suck... lol
  #7 (permalink)
Old 04-21-2008, 05:56 PM
Quote:
Wow! First time I've heard of that. Something was definately wrong there. I'll stick to the Cloye's "Street Tru Roller" for a cheap timing set. Unless I hear different here. Way too much crap to remove to change that out later, I'd rather get it right the first time. I'm just building a stroker, so I won't be turning the high RPM's.
  #8 (permalink)
Old 04-22-2008, 09:15 AM
They built it loose to be "extra" noisy. Since it was sold as a feature, I am sure they sacrificed performance for the noise. The big value of gears is to hold the cam true. Agressive cam ramps and higher spring pressures will factor more than RPM to needing gears vs a chain.
  #9 (permalink)
Old 04-22-2008, 05:47 PM
True, but I won't have either. I'd probably need some pretty agressive rams and high lifts to spin it with a carb.
  #10 (permalink)
Old 04-25-2008, 07:40 PM
Social Outcast
petes79f150 has a good reputation on FTE.petes79f150 has a good reputation on FTE.
Actually, it's the way the gears are cut that determines whether they're "noisey"or "quiet"- spur cut, like a regular timing chain set, or crown cut, like a ring and pinion. Downside to the gears?- they transfer harmful valvetrain harmonics, affecting cam timing moreso than a chain or belt drive.
+1 for the Cloyes true street roller.
Pete
__________________
The Hurrier I Go, The Behinder I Get.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
