Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 04-16-2008, 07:16 PM
screwy's Avatar
screwy screwy is offline
Garage is empty, add now
screwy is gaining momentum as a positive member of FTE.screwy is gaining momentum as a positive member of FTE.
Few quick questions about B99.
Does it suffer the performance loss like ethanol? Any modifications needed? Specifically on the 6.0? Any negative consequences? It can get is cold as -30F here, is there any mix that will hold up to this or just #2? What are roughly the gelling temps for the mixes?
Thanks!
__________________
2013 F-150 Super Crew Lariat, 4x4, 3.5 Eco, 3.55E
  #2 (permalink)
Old 04-19-2008, 08:10 AM
Pocket's Avatar
Pocket Pocket is offline
Pocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud ofPocket has much to be proud of
Ethanol sufferes up to a 35% decrease in energy compared to regular unleaded gasoline. Bio diesel is only around a 1% drop in energy compared to ULSD. On top of that, bio typically has a higher cetane rating than diesel, meaning it ignites quicker and burns more completely. All of this depends on the quality of bio diesel you get in your area. Bio is not federally regulated, but instead it is up to your state to set the guidelines for pump bio. So quality of bio can vary depending on where you live. Not all states require bio to meet ASTM standards.
As for temps, even #2 diesel will gel at -30. In those temps you are using winter blend, which is a blend of #1 and #2 diesel. Most pumps probably won't even sell B99 or even anything above B20 in the winter months due to gelling isssues. For concentrations of bio higher than B20, run that during the summer months.
__________________
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the Colorado diesel community.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
