Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2008, 07:42 PM
gene17847 is starting off with a positive reputation.
amp gauge
i got a good deal on a gauge cluster amp water and oil press, but it has no directions great deal lol i can get the temp and oil with no troubles but im not sure were to wire the amp gauge up to with an external reg can any one help me out?
  #2 (permalink)
Old 04-16-2008, 08:50 PM
catfish101's Avatar
catfish101 is starting off with a positive reputation.
What kind of gauge is it? There is more then one kind. What are the terminals marked on the back of the gauge. Some labeled the posts and some didn't. If you were backwards you just reversed the positive wires.
You don't see to many of these gauges anymore. I have heard of people, back in the day get, getting killed by wiring these up or working on them. 12 volts won't kill most people but 1 amp will kill most.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #3 (permalink)
Old 04-16-2008, 08:53 PM
its a off brand and not labled
  #4 (permalink)
Old 04-16-2008, 09:12 PM
catfish101's Avatar
How many posts does it have?
__________________
  #5 (permalink)
Old 04-17-2008, 07:02 PM
the name of the gauges ia Trico and the amp has 2 post
  #6 (permalink)
Old 04-18-2008, 12:00 AM
ford trans tech is starting off with a positive reputation.
if it is a true amp gauge and the power wire from the alt, must run through it , it wont be big enough unless it is rated to 120 amps , most of those aftermarket amp gauges are only for 60 amps , your diesel has a 100 amp alt
and a voltmeter is a better choice
__________________
89 F-350 CREWCAB DUALLY
  #7 (permalink)
Old 04-18-2008, 12:02 AM
catfish101's Avatar
Hook it up under the hood and see if it works. Put one post on the battery hot. You can use the terminal at the start relay. Hook the other wire to an ignition hot somewhere. See what it says. If it reads but backwards swap the wires on the posts. Be careful and don't hold the gauge. They can get you. You would be the only path to ground and that means dead generally.
__________________
  #8 (permalink)
Old 04-18-2008, 12:44 AM
this is DC current and isnt harmful unless your holding the burning wires in your hand, however AC current is
__________________
  #9 (permalink)
Old 04-18-2008, 04:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
Under the right conditions you can definitly feel 12 volts DC.
And if you think DC can't hurt you, try holding on to your home phone line with one wire in each hand when the phone rings.
That is only 90 volts DC.
High voltage DC is just as deadly as high voltage AC is.
Some of the early electric chairs were DC.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #10 (permalink)
Old 04-20-2008, 12:46 PM
magusjinx is starting off with a positive reputation.
Back in Edisons day the towns were all wired DC ...
__________________
Current:
1986 Ford F250 XL Exploder--4x4, 6.9 NA IDI, C6
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited P.O.S.--2.8L V6, Automatic ...
  #11 (permalink)
Old 04-20-2008, 01:04 PM
khadma's Avatar
Hawai'i Chapter Member
khadma has a great reputation on FTE. khadma has a great reputation on FTE. khadma has a great reputation on FTE. khadma has a great reputation on FTE. khadma has a great reputation on FTE.
Quote:
Amazing, but true.
__________________
1996 Bronco xlt 5.8,a/t,a/c,31x10.5 BFG's A/T
1999 Ranger supercab xlt 3.0, a/t
1984 Bronco 4.9l, 4spd manual
2002 F150 regular cab shortbox XL 4.2 a/t
1995 Windstar
2007 Explorer XLT 4.0 a/t
2005 Escape XLT 3.0 a/t
Member of the Hawai'i Carpenters Union - Local 745
Darren
  #12 (permalink)
Old 04-20-2008, 08:10 PM
actually edison wanted a/c voltage banned
he made tours of large towns and would electricute a dog as a demonstration of how dangerous a/c was he called it being westinghoused
of course he had a patent on the use of d/c current
but back to our trucks , if the 12 volts of d/c were that dangerous you wouldnt be able to buy a battery or even see it in your vehicle due to safety precautions
__________________
  #13 (permalink)
Old 04-20-2008, 09:29 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
You know your history, ford trans tech. From what I read its all true. Edison later quietly admitted that his stance on AC was one of his regrets (though I'm still mad at him for what he did to Tesla). The first human electricution was a total flop, not nearly as "humane" as was claimed at the time.
The only time I ever felt 12V is if a fresh scrape on my skin came in contact with a 12 wire. Even got the odd mild electric tingle when I was younder and making less than proper wiring for model trains. I wouldn't call 12V dangerous.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #14 (permalink)
Old 04-20-2008, 10:11 PM
catfish101's Avatar
AC or DC doesn't matter. 1/2 amp will make you graveyard dead.
__________________
  #15 (permalink)
Old 04-21-2008, 12:07 PM
Were the old generators on vehicles ac? Then rectifyed to dc?
__________________
Current:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
