CDR? I think it stands for Crankcase Depression Regulator or something like that. The way I understand it is it's sortta like a PCV valve for IDIs.
Gotta' RINSE it out with gasoline, no blowin' it out with an air nossle. If the internal diaphram is broken and chunks come out of it you have to replace it.
The 7.3 Turbos have it on the driver's side valve cover. Not sure about NAs or non-factory turbos.
This is pretty basic stuff I learned about I think the first day I was on this site so you may know about it already. Especially if you put on your own Turbo "kit" and had to relocate it.
No offense to Blacksmoke, I just thought royzell probably already knew about it and I didn't want to take credit for knowing what to do with it, I learned about it on here.
It is a VERY possible cause of the problem though.
well when my CDR went out it would put oil into my intake and the smoke would disipate as i went down the road
RWIW... Moroso and others make a oil seperator for race cars that have a dry sump... nice looking unit.. I've ben wondering how I could adapt one to work on my truck..
__________________
"YOU'RE JUST JEALOUS THAT THE VOICES TALK TO ME"
1991 F250 X/cab, 4X4, 7.3l, w/ATS Turbo, Lariat, egt & psi gauges, 33" tires, and now with a 5th wheel hitch..
No Blue smoke at all except on downhill, loaded, as described
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, aftermarket modified powerstroke turbo with intercooler
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
Hi guys, the timing hasn't been touched in ages. 'Turns out, the genius that installed my turbo completely removed the CDR.
__________________
93 Honda Accord
