Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-16-2008, 03:04 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
My FM70 Mod
I like my FM70 muffler I have but I want just a tad more sound out of it. I was going to buy a Magnaflow muffler but I figured I would try to modify my FM70 first to save some $$$ and if I screwed it up I would just buy a new muffler.
What I did was block off the one chamber directly inline with the inlet (Small Hole) in the picture below.
I took a piece of 10 Ga. Steel Sheetmetal and cut out a 1 3/4" circle to fit inside of the hole to block off the chamber. I used some weld through primer on the back of the disk I cut and MIG welded the disc to the opening blocking off the chamber. I welded the disc flush with the top of the chamber opening. After I finished welding I sprayed some high temp paint over it to prevent rusting and I was done.
Overrall I'm happy with the result. The muffler has more bark to it but not overly much. I have about 800 miles on it so far and I have not noticed any drone at any rpm range. I'll eventually get a video clip and post it.
  #2 (permalink)
Old 04-16-2008, 03:51 PM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids is gaining momentum as a positive member of FTE.
Nice! I have a FM 70 to and i watned a little more noise out of it. So i drilled some holes in the pipe where before the pipe meets the inlets. It worked and i have a little bit more noise.
  #3 (permalink)
Old 04-17-2008, 06:35 AM
Big Orn's Avatar
Big Orn Big Orn is offline
Big Orn has a very good reputation on FTE. Big Orn has a very good reputation on FTE. Big Orn has a very good reputation on FTE.
Good job, dkf!
Now where's them sound bytes!
__________________
Staring too long at your own navel leaves one only to stare at the difference in another’s. The reaction to that difference tells much about one’s inability to stare at own navel. - krewat 2006
  #4 (permalink)
Old 04-17-2008, 02:29 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Rep points for that one
Ingenious! I wonder though, what it does to the flow of the muffer? Not much, I'm gathering, given that chamber right in-line with the inlet seems to have a dead-end right after it anyway...
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #5 (permalink)
Old 04-17-2008, 05:42 PM
dkf's Avatar
dkf dkf is offline
I don't think it hurt the flow of the muffler anymore than when the exhaust was allowed to go into the chamber, but who knows.
The main reason I pulled the exhaust was to replace the section of pipe between the cat and muffler. I had a local exhaust put my cat-back system on because I didn't feel like dealing with it and a pipe had to be custom bent. The shop didn't have a Mandrel bender so as you may have guessed the tube was collapsed down to about 2.3" at the 2 bends on the pipe. Those bad bends are not good and drove me nuts. While I had the exhaust apart I figured I modify the muffler as well. Below are some pics of the old pipe and the new pipe I fabbed up out of two 3" 45 degree magnaflow stainless mandrel bends. Since doing the work I've noticed the top end power to be better.
Cut away pic of the old pipe from the muffler shop
Pics of the new pipe I fabbed up.
  #6 (permalink)
Old 04-17-2008, 06:57 PM
fordmdb's Avatar
fordmdb fordmdb is offline
FTE Sponsor
fordmdb is gaining momentum as a positive member of FTE. fordmdb is gaining momentum as a positive member of FTE.
Very nice set up. I wish mine was that new. Let us know when you have time to get that vid...
__________________
www.5startuning.com email me here: mike@5startuning.com
843-667-3595
See Group Buy here http://www.ford-trucks.com/forums/90...group-buy.html
SCT Custom Tuning Dealer / Level 4 Engine Controls / In-House DYNO
2008 V10 F350 SC ,2005 F150 5.4L , 2002 GT Stang , 2008 Ford Edge, 1999 V10 F350, 2003 F250 5.4L V8, NEW! Project Tow Haul 2000 F250 V10
  #7 (permalink)
Old 04-17-2008, 08:22 PM
Do u have a before sound clip to? Just so we can see the difference?
  #8 (permalink)
Old 04-18-2008, 01:32 PM
dkf's Avatar
dkf dkf is offline
Quote:
No I don't have a before sound clip. I'll get a video soon but I've been having problems extracting video clips.
Could you possibly post my video when I get everything figured out?
  #9 (permalink)
Old 04-18-2008, 06:58 PM
rustyfuryiii rustyfuryiii is offline
rustyfuryiii is starting off with a positive reputation.
dkf,
That's some fine looking pipe before the muffler. Kinda looks like copper.
RustyFuryIII
__________________
'96 Buick Roadmaster Estate LTD/CE Station Wagon, 5.7L LT1 detuned Vette motor, 2.93:1 open rear, and factory 5000lb tow package
'06 F250XLT SD CC V10 6spd manual 4.10 LS, 8' box, 4X2
  #10 (permalink)
Old 04-18-2008, 07:16 PM
dkf's Avatar
dkf dkf is offline
Yeah the pipe changed a purplish/red color, it was shiny stainless. The pic was taken after about 500 miles on it.
I got a sound clip but I'm having problems uploading it through Photobucket.
  #11 (permalink)
Old 04-21-2008, 08:01 PM
dkf's Avatar
dkf dkf is offline
Finally got my video uploaded. The camera was a little close.(6'-7' away) For those who don't know truck has Throley headers/ypipe, 3" Dynatech cat, FM Force 2 Cat-back w/FM70 with above mod and a 4" x 12" tip.
  #12 (permalink)
Old 04-21-2008, 08:30 PM
fordmdb's Avatar
FTE Sponsor
That sounds really good.
__________________
843-667-3595
  #13 (permalink)
Old 04-21-2008, 09:09 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
sounds great! nice job
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
10 Escape XLT
This isn't your father in law's Buick. Step back
and no one gets hurt!
  #14 (permalink)
Old 04-24-2008, 01:53 AM
Jason Lewis's Avatar
Jason Lewis Jason Lewis is offline
1996 Ford F-150
Jason Lewis is gaining momentum as a positive member of FTE.
Clean !!!!
__________________
1996 F-150 Lightning Clone Look in My gallery
"Pushrod all the way"
http://www.youtube.com/watch?v=kp4c_fCu3FI
  #15 (permalink)
Old 04-25-2008, 02:19 PM
cnelso48 cnelso48 is offline
cnelso48 is starting off with a positive reputation.
Quote:
About how much has your set up cost you? From reading your post it seem like you really like what you have got. I was thinking aobut getting the Banks set up just a little pricey for me
Tags
catback , fm70 , photobucket , v10monster
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
