Got a cargo aero? Seeking window grille.
I have an Aerostar cargo van with the cage behing the drivers seats, shelving in the back, dual rear doors instead of a liftgate, and chrome wire grilles on the inside of each window.
Well, I am missing the wire grille for my rear right door window. Hoping to find one.
Thanks.
__________________
1996 Aerostar Shorty Cargo Van (3.0) 211k
Work Done: axle bearings(offset), front bearings, shocks, tie rod ends, inner tie rod, driveshaft ujoints, transm filter & flush, differential fluid change, fuel filter, PCV Valve, CPS, 2 Idler pulley bearings, tensioner pulley bearing, front & rear brakes, new brake lines, air filter, new muffler.
