Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-16-2008, 01:22 AM
LostMayhem is starting off with a positive reputation.
Engine Problem
Hey I was wondering if anyone could help me out. My 02 lightning is sputtering when i am idle and vibrating alittle bit more than ussual. I just recently had a spark plug replaced because it shot out, and this problem began after the spark plug was replaced. When im in drive and i am stopped the RPM needle starts to move up and down alittle bit between .5 and 1. Does anyone know what could be causing this, and if it could be causing damage to the engine. The service engine light also came on when the spark plug shot out and has not turned off since i got it replaced. I would appreciate any help. thanks.
  #2 (permalink)
Old 04-16-2008, 01:48 AM
Stewart_H's Avatar
I Have A Need 4 Speed
Stewart_H is gaining momentum as a positive member of FTE.
How was the plug launch fixed? Timesert or head replacement?
Was the old COP also replaced? If so, I'd check to make sure the COP was plugged in after the repair was done. Also make sure the injector was plugged back in.
Who did the fix? A shop or Ford? I'd assume someone else other than Ford since the SES light wasn't cleared.
Have you scanned for the DTC code? If so, what is it?
If you need to scan for the code, you can borrow/rent a code scanner at just about any auto parts store such as Kragens, Autozone, Napa, etc.
You can also do an in-truck self diagnostic using the digital odometer.
After you get in your truck, before you turn the key at all, press and hold the odometer trip reset button.
Once you turn the key to the ON position, and the lights on the odometer read-out change, let go of the button. Press the reset button to scroll through the menu. If you press and hold it too long, it will clear out and go back to the mileage.
Look for the menu that says DTC. If you have a code, it will say DTC2145 or something...OR DTC NONE for no codes.
It should be noted however, the self-diagnostic isn't foolproof. My handheld scanner has shown codes present when the self-diagnostic has shown no DTC's present.
Also, check for any vacuum lines that have become disconnected.
Stewart
__________________
1999 F150 Lightning (work truck)
- Woodbine Motorsports built block
2000 PSD 4X4 Excursion (wife's)
- John Wood tranny, DP-Tuner, AFE, MBRP 4", BDP 1.0, Overboost Annihilator, V & B code springs, Hellwig rear sway.
  #3 (permalink)
Old 04-28-2008, 05:36 PM
Fordfreak! is starting off with a positive reputation.
Sounds like a bad coilpack,if not then i would def check the thread job,worst case,possible head damage,upgrade with a set of patriot heads.good luck
  #4 (permalink)
Old 04-29-2008, 12:48 AM
Stewart_H's Avatar
Quote:
Originally Posted by Fordfreak! View Post
...worst case,possible head damage,upgrade with a set of patriot heads.good luck
Garbage heads.
Worst possible choice you can make in an aftermarket head for Lightnings, based on all the posts and threads on the other Lightning forums.
Patriot heads are only good if you use the bare heads and build them yourself, or trust your engine builder to assemble the heads with the proper springs, valve guides, valves, etc.
Stewart
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
