Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-15-2008, 10:10 PM
raydav is starting off with a positive reputation.
Intercoolers
I am working two vehicles.
1984, stretch E350, 89 7.3 IDI, E4OD, 3.5 dually.
2001, E350 cutaway 22' long 10' high, 7.3 PSD, 4R100, 4.1 dually.
The 2001 does not have an intercooler and the 1984 is not yet turbocharged. Putting an intercooler in a van does not seem trivial.
The only obvious place I see for them is under the vehicle, to the rear of the trans, with fans. The 2001 has a huge amount of space, but would require a large amount of plumbing.
I am currently collecting parts for the 84. So far I have two T3/T4 turbos that will mount close to the outlets of the stock manifolds, two temp gages, three pressure gages, and an electric oil pump for an oil system. It will have a full dual exhaust.
I am mostly concerned with pulling a load up mountains so pressure lag is not critical, but still kinda important.
Is an intercooler worth the trouble? And how much good will it do with all that extra pipe?
Ray
__________________
Ray Davison
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-16-2008, 11:50 AM
littleme13's Avatar
littleme13 has a good reputation on FTE.littleme13 has a good reputation on FTE.
intercooler under the truck is a bad idea, they dont like rocks and stuff too much. mount it in the front. they need a lot of air to work and the coolest air possiable. by the tranny your gonna have hot hot air commin off the engine and trans excpesially if your pullin up grades.
__________________
-BLING investigator
Tony
Quote:
Originally Posted by dragogt
Na, just rip off the finder's and take a bfh to the firewall, she'll fit like a glove.
MORE
Military Online RElay
military photo contest
  #3 (permalink)
Old 04-17-2008, 10:42 AM
[quote=littleme13;6046401]mount it in the front.
Have you ever seen a diesel in a van? The only "in the front" is hang it on the bumper, or maybe lay it on the hood.
So again, just how much trouble is an intercooler worth?
Ray
__________________
Ray Davison
  #4 (permalink)
Old 04-17-2008, 10:54 AM
Lead Head is gaining momentum as a positive member of FTE.
I'm sure you can squeeze an intercooler in between the radiator and the grille.
  #5 (permalink)
Old 04-17-2008, 02:29 PM
littleme13's Avatar
Quote:
thats what i ment by mounting it in the front, sorry for the confusion. even if you have to go with a smaller or thinner one your better off then not having one at all.
__________________
-BLING investigator
Tony
MORE
  #6 (permalink)
Old 04-17-2008, 07:22 PM
Quote:
There was no confusion. I knew what you meant. But I am not sure you have ever seen a van. In order to fit, an intercooler would have to be the thickness of an AC condenser, because that barely fits.
Yes, I could move the condenser underneath; it would be much easier to blumb. The second condenser in the 2001 is already underneath. But I am not finding intercoolers as thin as that.
Ray
__________________
Ray Davison
  #7 (permalink)
Old 04-17-2008, 07:55 PM
Quote:
Ok, in both cases I could relocate some things and get some sort of intercooler in front of the radiator. That leaves the plumbing. There are no open spaces between turbo, grill and intake on either.
Oh well, we don't want things to be too easy.
Are you sure it will help?
__________________
Ray Davison
  #8 (permalink)
Old 04-17-2008, 09:17 PM
Maybe go to a junkyard or some other place that has diesel vans, and see how the 6.0's intercooler is setup
  #9 (permalink)
Old 04-18-2008, 10:04 AM
littleme13's Avatar
yes an intercooler will help. do you need it no. but like lead head said look at other vans and see how they have it wedged in there. with out it your going to have significantly higher intake temps, you want to coolest air possiable going into your engine for the power benifit. as for routing tubing, get the cooler mounted and then route the lines. just make sure the inlet and outlets are on the top or bottom where you can actually use them.
__________________
-BLING investigator
Tony
MORE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
