04-15-2008, 07:57 PM
All the air intake system is hooked up as it should be,i just pulled the tube out that is used as crankcase ventalation and shoot the start fluid in..It the tried to start,after that it just like if the ignition system had been disconected,but shoot it with starting fluid again and it tries to start,apparently the injectors are not gettingtheir signals to pulse..i have tried switching the relays around in case it was a bad relay,no dice.
Checked all the fuses within the box as the relay and there all good.are any of the fuses inside the cab related to the efi system?because i haven't checked them as i didn't think a fuse in the common fuse panel would stop the truck,,maybe im wrong?
Anybody got ideas or no if there is something i can check to see if the injectors are gettinf their signal and firing/pulsing,,wayne
