Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-15-2008, 07:50 PM
waynebo is starting off with a positive reputation.
Won't start
Have 2000 b3000 4x4 that didn't run, i found the fuel pump was bad and replaced it.That fixed it and drove it for a while and then parkedit for a few weeks and i now have a no start problem.
Ckecked fuel pressure and its fine,can spray startinf fluid and it tries to start but as soon as the starting fluid is gone its back to as if it had no spark,,which it does because with the starting fluid it tries to run.
I have a hanes manual but that is useless,i feel that the injectors are not being energized but the manual doesn't even mention them, little on tell you how too trouble shoot the system..
This is a flex fuel for what its worth,,any help appreciated..wayne
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-15-2008, 07:57 PM
All the air intake system is hooked up as it should be,i just pulled the tube out that is used as crankcase ventalation and shoot the start fluid in..It the tried to start,after that it just like if the ignition system had been disconected,but shoot it with starting fluid again and it tries to start,apparently the injectors are not gettingtheir signals to pulse..i have tried switching the relays around in case it was a bad relay,no dice.
Checked all the fuses within the box as the relay and there all good.are any of the fuses inside the cab related to the efi system?because i haven't checked them as i didn't think a fuse in the common fuse panel would stop the truck,,maybe im wrong?
Anybody got ideas or no if there is something i can check to see if the injectors are gettinf their signal and firing/pulsing,,wayne
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
