6.0 Check Valves Fuel Line Setup
I need some pics or input on how some of you folks are setting up your fuel line with check valves on your 6.0PSD. Are the OEM fuel lines cut? Using hose clamps to run the check valves inline? Are new lines being fabricated from scratch using tee's for the check valves etc??
