Truck stalls when put into gear - Ford Truck Enthusiasts Forums
Old 04-15-2008, 12:47 PM
sum_weirdo sum_weirdo is offline
sum_weirdo is starting off with a positive reputation.
Not sure if this is specifically a drivetrain issue or not but virtually every time I put my truck into gear after it's been started, it stalls. Doesn't matter if it's a cold start or warm, it'll seem to be idling fine and then when I put it in D or R it sputters and dies. Tried holding the gas while I shift with limited success, the only thing that really works is to immediately get moving after I shift and that's not always an option. The truck has a 460 backed by a C6, can anyone shed some light on this?
Old 04-15-2008, 02:17 PM
gearhead351 gearhead351 is offline
gearhead351 is starting off with a positive reputation.
Quote:
That sounds like a fuel problem. I would check out your fuel filter and make sure your carb is squirting fuel. You didnt say if you could rev it up or anything.
Old 04-15-2008, 02:38 PM
Sorry. Yes I can rev it. But when I put it in gear at first the RPMs go way down and the truck stalls. If I try to rev it while shifting it'll probably still stall. If I shift and right away pull out then the truck idles fine.
Old 04-15-2008, 05:03 PM
sclariat sclariat is offline
sclariat is starting off with a positive reputation.
I believe your torque converter is pooched.
Old 04-15-2008, 05:11 PM
Dang, you think so? Anything I can do besides change it?
Old 04-15-2008, 05:23 PM
Ya, plant flowers in it and make the truck your new lawn ornament. lol
But I would check the oil and stuff...see if it smells burnt or if you can see any metal floating around in there.
Old 04-15-2008, 09:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
How could it be the torque converter? I don't understand. It sure sounds like an engine problem to me.
Old 04-15-2008, 09:42 PM
Your torque converter is supposed to supply stall in order to idle. When you put the tranny in drive while you hold the truck from moving with the brake, it kills the engine....or something like that. I suck at explaining stuff. much better at working on it.
Edit: I just read your signature, lol. please tell me if you think I'm wrong but also your explanation would be appreciated
Old 04-16-2008, 08:07 AM
I think you're wrong.
The torque converter is supposed to slip to allow the engine to idle without stalling. I have never seen one fail to do this, and I can't think of a way a torque converter could fail and not do this. I know of a few ways a torque converter can fail and not transmit torque to the transmission, but then the truck acts like it is in nuetral all the time.
I think there is something wrong with the engine that prevents it from idling with some load on it. A vacuum leak can do this, a carb problem, wrong timing, low idle speed, etc.
Old 04-16-2008, 08:50 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
On newer, electronically controlled vehicles, a torque converter clutch that is not releasing will cause this.
However, since we seem to be discussing a vehicle that predates this and that I have no relevant experience with.....
Steve
Old 04-16-2008, 09:46 AM
Hmm. Well it idles at about 700 RPM in gear (when I get that far). Maybe it can be tweaked a little more. I'll check all the vacuum lines too when I get a chance.
Old 04-19-2008, 02:10 AM
kdy72601's Avatar
kdy72601 kdy72601 is offline
kdy72601 is starting off with a positive reputation.
check the vacum line going to the vacume modulator or the vacume modulator its self could be the cluprit.
2003 ED Expedition stalls when put in gear davidmolina 1997-2006 Expedition & Navigator 8 07-30-2014 11:19 PM
460 Idle rough and almost stalls when put in gear daddylee100 1987 - 1996 F150 & Larger F-Series Trucks 5 03-02-2014 09:40 PM
Trans issue... Krisx125 1994.5 - 1997 7.3L Power Stroke Diesel 2 12-22-2013 05:43 PM
tranny causes engine stall? reddogracing 1999 to 2016 Super Duty 7 09-17-2012 06:59 PM
Truck stalls when put in gear and etc.... FastBlack 1987 - 1996 F150 & Larger F-Series Trucks 16 07-19-2008 11:05 AM
Tags
1988, 98, c6, cuts, dies, drive, engine, f150, f350, gear, kills, motor, put, stalls, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
