Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-15-2008, 12:41 PM
ad7 ad7 is offline
ad7 is starting off with a positive reputation.
Do I have AOD?
As opposed to ADD? :-)
Anyway, I have an 85 302 auto, two wheel drive. It does
have a gear that it drops into around 45 or above.
The reason is that I'm looking at a new carb, and some don't work
with automatic overdrive.
Thanks.
  #2 (permalink)
Old 04-15-2008, 02:01 PM
Archion is gaining momentum as a positive member of FTE.
If it shifts three times, then it is an AOD, also, is there a second cable going to a lever on the side of the trans next to the main shift linkage, or what does the shift indicator read as? "PRND21" or PRN'OD'D1".
__________________
____________________________
My 2008 Truck Carlisle Gallery!!!
Matt
1986 F-150
302/5.0L
AOD 4X4
  #3 (permalink)
Old 04-15-2008, 05:12 PM
LARIAT 85 is starting off with a positive reputation.
If you are going to use a Motorcraft carb, their are certain models that use an AOD-specific throttle lever. You can use most aftermarket carbs with the AOD transmission. BUT you must make SURE that you get an AOD throttle bracket that mounts to the throttle lever on your particular carburetor. Holley makes one for their carburetors, and so does Edelbrock.
Then, make SURE you get the transmission throttle valve pressure correct! If it is not adjusted correctly, you will destroy your AOD in a very short time. I would suggest going to a reputable transmission shop to make the transmission adjustment.
  #4 (permalink)
Old 04-29-2008, 11:24 AM
ad7 ad7 is offline
It is PRND21, with a D inside a circle.
  #5 (permalink)
Old 04-29-2008, 11:52 AM
Redneck1465 is starting off with a positive reputation.
Than it is an AOD trans.
  #6 (permalink)
Old 04-29-2008, 12:00 PM
ad7 ad7 is offline
Thanks.
Hey Lariat 85, thanks for the warning on the tranny adjustment. Yeah,
I'll be looking at a replacement carb, methinks.
  #7 (permalink)
Old 04-29-2008, 12:13 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
1980/89 Transmission Codes
1980/89 Ford Light Truck Parts Catalog
Automatic Transmission CODES as listed on the Certification Label
E = E4OD = 1989
K = C6 = 1980/89
T= AOD = 1981/89
Correct FoMoCo Nomenclature > >
AOD = Automatic Over Drive aka AOT = Automatic Overdrive Transmission
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #8 (permalink)
Old 04-29-2008, 07:02 PM
Holmesuser01 is starting off with a positive reputation.
I sure wish I had an AOD in my truck. Just a wish, though. The C6 that I have is an outstanding piece of work itself.
__________________
1983 F-150 w/ 351 Windsor, C6 tranny, A/C, and cruise. 180K, and everything works!
Now if I could just get it to pass gas stations.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
