Who actually uses Royal Purple? - Ford Truck Enthusiasts Forums
Old 04-15-2008, 11:28 AM
azfordf100man's Avatar
azfordf100man azfordf100man is offline
azfordf100man is starting off with a positive reputation.
Hey guys,
I know RP has been discussed alot, but I was just curious as to who is running it as there main oil? Are you happy with it's overall performance?
The reason I am asking is because RP is the current fill in my mark but I'm wanting to find out more about this oil before I start using it every oil change. BTW, so far I have 4K on this OCI and have been satisfied so far.
Thanks in advance,
Mike
Old 04-15-2008, 07:52 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Not me....just good ol ford 5w20 semi syn
Old 04-15-2008, 08:29 PM
hofuf hofuf is offline
hofuf is gaining momentum as a positive member of FTE.
I've been using it for about 7 years. Started when my neighbor (Rotating equipment engineer for Shell) recommended it.
Old 04-15-2008, 09:10 PM
Blu04XLT Blu04XLT is offline
Blu04XLT is starting off with a positive reputation.
Heard of RP but not familiar with it. I've always used what Ford recommends per owners manual Motorcraft 5W20 and have had no problems. Very low cost 5qt. jugs at Wal-Mart for $10.36/jug last week. Motorcraft filters less than $4.00.
Old 04-15-2008, 09:31 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Not for the engine. But their other products like Gear oil, MTF,ATF and grease. Their prices are very decent on those products and with those fluids going 30k and beyond before service the cost is not bad. I get RP gear oil for 8.99 and ATF for 5.97 at the local parts house.
Old 04-15-2008, 10:40 PM
BChance's Avatar
BChance BChance is offline
BChance is starting off with a positive reputation.
I run RP in everything on the truck (93 F350 460, E4OD). Diffs, t-case, transmission is coming(rebuild just installed by a shop on a road trip, soon as it hits about 10000 miles, it gets RP too..) and engine. I usually use it in the radiator too, but last time they were out so I used Red Line water wetter in it.. (RedLine is also very good oil, btw, but where I live, the RP is available local, RL is not)
RP makes a really good gun oil too..
My wifes Land Rover has always had a fairly "noisy" engine since it was new..Dealer uses and recommends Valvoline synth, I used Mobile1 in it for awhile and it was still "noisy"..just a bit clattery sounding. Put RP in it and while it is not completely silent, it IS noticeably quieter.
Old 04-16-2008, 07:32 AM
saftman saftman is offline
saftman is starting off with a positive reputation.
I ran trhe Ford stuff till it was broken in. Switched to Schaeffer's 5w40 and then to their 15w40. Neither one was doing much more than the Ford stuff according to analysis. I just got 15 gal. of Royal Purple. Will be putting it in soon.
Old 04-16-2008, 12:26 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
My only direct experience with RP motor oil was not very good, but the application does not relate very well to a Ford V-8. In a Suzuki motorcycle, which shares engine, transmission and wet clutch from the same oil supply, RP sheared down within 1000 miles. I noticed gear shifting went to heck. Shell Rotella T synthetic, which is cheaper and supposedly made from inferior base stock (Group III) did not fail like that. Like I said, the applications are quite different.
Jim
Old 04-16-2008, 02:02 PM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
Motorcycle oils have significantly different requirements.
BTW, a few days ago I saw it advertised for almost a buck cheaper than Mobil1.
Old 04-17-2008, 11:02 PM
Ed Ed is offline
Ed is gaining momentum as a positive member of FTE.
I have used Royal Purple 5w30 oil and a Motorcraft FL400s oil filter in my Aerostar van with excellent results. No leaks, Did not use a drop of oil between changes. 144K miles on the van at the time, I used it in the hot NoCal summer, triple digit heat outside, freeway driving, stop and go traffic with the AC blowing ice cold.
Engine ran at normal temperature with Royal Purple 5w30.
Garage floor spotless, no drips or leaks with Royal Purple.
Engine turns over and starts immediately with (you guess it) Royal Purple.
I'd use any of their products, their MAX ATF is excellent, as well as their Purple Ice for the radiator.
Plus I've seen full race motors at the drags run Royal Purple street oils, these are American Muscle Cars, running low 9s 165+ MPH through the quarter mile. Royal Purple is a good oil, use with confidence.
Old 04-20-2008, 12:58 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.Sycostang67 has a very good reputation on FTE.
I run it in both mustangs, the capri will have it as soon as it's due for another OC. The truck leaks/burns too much so I use cheap oil in it right now. When I put another motor in it this summer though, it will end up with RP as well.
Old 04-20-2008, 01:38 AM
christcorp's Avatar
christcorp christcorp is offline
christcorp is gaining momentum as a positive member of FTE.
I'm not sure if using Royal Purple is beneficial or not, but I have noticed some differences. I have a 1994 Ford F250 with a 7.5l 460ci V8. If you are familiar with the temp gauge, it has 2 lines on each end with the word NORMAL in between them. Using dino oil, Mobile 1, and Wal-Mart Super-Tech motor oil, the temperature gauge always showed around the "O" in the word normal. Using Royal Purple, it usually runs half way between the first line and the letter "N". Obviously much cooler. I went back and forth twice and confirmed the drop in temperature. Now, whether or not running cooler is good or not, I'm not sure. Some may say that if the engine runs too cool, the computer will try and run it richer; thus worse gas mileage and more carbon. Others say the opposite.
I'm not sure what if any, changes in fuel efficiency Royal Purple has. I experiment so much with things such as Acetone, Lucas, Seafoam, and others that I don't have a consistent enough baseline to determine if Royal Purple helps gas mileage or not. But I do know with Royal Purple, the engine runs cooler and smoother. There's almost no hesitation or stutter. Especially when idling. It's never bad, but you can tell a difference with Royal Purple. It's not a placebo affect, just hard to explain.
Now, is it worth using Royal Purple or not, that is the question. Because of the climate where I live, and the extreme altitude I drive at, I change the oil in my truck every spring no matter the mileage. (Mileage is around 6000 miles. I know synthetic can go more than that, but again with the extreme temperatures and high altitude, I change it once a year no matter what. Royal Purple is found at our local Checker Auto. Normally it's $6.99 a qt, but almost anytime I check it out, there is a sale down to $5.97 a qt. So, for the 5 qts I need, that's $30. If I buy the 5 qt bottle of Mobile 1 at Wal-mart, it's $24. So, $6 more isn't bad. If I buy the Super-Tech synthetic at Wal-Mart, it's only $14. The $16 is a big difference. Some people say that as long as the motor oil meets all the specs, then you are better off buying the cheaper oils. Some actually believe that Royal Purple, Mobile 1, etc... make a difference.The way I figure it; No one has ever really said that Royal Purple has DAMAGED their vehicle. So, for the extra $6-$16 for an oil change; once a year; thus equating to $0.50 to $1.35 a month. For that little extra, it was/is worth a try. So far, I haven't had any problems with it. Again, it runs significantly cooler engine; (Not sure if that's good or bad) and it sound smoother.
Old 04-20-2008, 07:33 AM
BChance's Avatar
jimandmandy, I'm curious, did you use the RP MaxCycle, or the automotive oil in your Suzy-Q?
Old 04-20-2008, 06:02 PM
Quote:
Originally Posted by christcorp View Post
I Now, whether or not running cooler is good or not, I'm not sure. Some may say that if the engine runs too cool, the computer will try and run it richer; thus worse gas mileage and more carbon. Others say the opposite.
As far as I know, the engine computer uses the coolant temperature to determine whether the engine is warmed up, or not.
Old 04-22-2008, 03:23 AM
Ed Ed is offline
Talking
[QUOTE=aurgathor;6063184]As far as I know, the engine computer uses the coolant temperature to determine whether the engine is warmed up, or not.
EXACTLY! thanks for saying that as I was just about to. In fact, once the thermostat opens at or around 193 degrees, it's what the computer looks at to determine fuel mixture, which even then, has been reduced and it's not as rich as it would be during initial cold startup.
Quality oils help absorb internal, ambient heat, and also heat during heat soak conditions, which is always a GOOD thing.
An oil will never cause the engine to run too cool, as to cause problems with sludging, ect. Frequent short trips will, but that is not the fault of the oil, per se.
kennebell dyno graph and some pics V10RP Modular V10 (6.8l) 9 11-22-2014 09:33 PM
Petro based vs synthetic oil in high mileage 6.0l nufan4ever 6.0L Power Stroke Diesel 10 08-20-2014 12:07 PM
1979 f100 4.6 swap ? BAFords 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-13-2013 02:30 PM
New box adapter for old 5th hitch on new truck! nswilliams 1999 to 2016 Super Duty 5 04-04-2012 12:27 PM
New trailer... Weight distributing hitch? schwank Excursion - King of SUVs 12 06-29-2011 03:28 PM
Tags
bad, capri, car, forums, gas, gear, good, increase, lincoln, mileage, oil, oilford, purple, rotella, royal, wi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
